SB3 problem of the day
0 Members and 1 Guest are viewing this topic. Read 1453 times.
pugs
« on: 30 Dec 2005, 07:08 pm »
Yesterday I lost my internet connection.  Today, the internet is OK, and I was playing music, but all of a sudden after I changed songs, I lost sound.  The SB3 is playing and I have 90% signal strength but there's no sound at all.  Volume on the SB3 is at max, and my Odyssey preamp is still on.  I rebooted the router and computer, but didn't have any luck.  Any ideas?  This thing sure is frustrating.
ctviggen
« Reply #1 on: 30 Dec 2005, 07:24 pm »
What else did you do (if anything)?  I lost sound when I tried to enable "fade in and fade out".  I had to disable this and reset everything.
pugs
« Reply #2 on: 30 Dec 2005, 07:35 pm »
I clicked on another album to play on Slimserver.  Since that I can't get any volume no matter what I play.  I get sound out of my system when I switch sources (TV).
pugs
« Reply #3 on: 30 Dec 2005, 07:37 pm »
I just turned off the battery power and turned it back on.  I hear music now  :?: .
