Help with Foobar2K and ASIO
0 Members and 1 Guest are viewing this topic. Read 1938 times.
Marbles
« on: 30 Dec 2005, 02:17 pm »
I'm trying to play F2K (v8.3) with ASIO upsampled with Secret Rabbit to 24/96 and whenever I select Asio as the output, it just sounds like crap.
When I use Waveout or Directsound it sounds incredible.
MAybe I have the wrong version of ASIO.
Anyone know an English speaking site where I can download the latest ASIO for FOOBAR running on XP?
Thanks for any help.
ted_b
« Reply #1 on: 30 Dec 2005, 06:19 pm »
Kernel Streaming is clean and bit perfect too, and bypasses the Windows kmixer, so its an equivalent alternative to ASIO.  I use it.  Sorry, don't have an ASIO answer, though.  Waveout is bad.
Marbles
« Reply #2 on: 30 Dec 2005, 06:34 pm »
Thanks Ted.
I just spoke to Steve Nugent and apparently ASIO is a processor hog and and I can't use it with other programs open.
Waveout sounds pretty amazing on this gear.  I think I will just stick with it in the short run.
I like it a bit better than Directsound.
As far as Kernel Streaming, when I try to select it, there really isn't any choices to make, so it seems with the M-Audio drivers it's not available to me :-(
ted_b
« Reply #3 on: 30 Dec 2005, 06:44 pm »
Should be there if you downloaded special install version, or go and get it off foobar site.
http://www.foobar2000.org/components.html
I use it cuz it bypasses noisy Windows kmixer (the Windows sound app that shows all the slider bars, etc.).  If waveout sounds fine, then ok.
Jon L
« Reply #4 on: 30 Dec 2005, 06:56 pm »
Oops, Marbles, I posted this at your other thread:
"Hmm. Too bad ASIO isn't working; is it skipping and stuttering? Have you tried: 1) In Transit Menu window, set "Latency" to Highest (increases buffer) and 2) Bring up Windows task manager (cont-alt-del) and choose Foobar and make it "highest priority." When you use 96kHz upsampling, ASIO requires Tons of buffering to prevent skipping."
By ASIO sounding like "crap," you do mean stuttering/skipping, not bad sound quality without stuttering, right? It's not really b/c ASIO is processor hog; ASIO uses very minimal processor power.  It has more to do with the delicate balance among priorities various software and hardware compete for.
Kernel Streaming does not work with M-Audio Transit.
ASIO4All does work with Transit if ASIO dll plugin has problems; however, ASIO4All has its own problems sonic-wise compared to ASIO dll, especially if 96kHz upsampling is used.
ted_b
« Reply #5 on: 30 Dec 2005, 07:14 pm »
Oh well, no KS.  My son uses the good older M-Audio Sonica (not the newer Theater, yuck) and KS works fine.  I use the Chaintech.  Hell, if waveout sounds good, don't fix what ain't broken.
Marbles
« Reply #6 on: 30 Dec 2005, 08:40 pm »
Thanks guys....Jon L, those changes WORKED!!!
Thanks again!! :rock:
