0 Members and 1 Guest are viewing this topic. Read 4008 times.
My CPU is a 1.6 GHz Pentium 4. I have 256M ram.
I strongly suggest a cpu upgrade
QuoteMy CPU is a 1.6 GHz Pentium 4. I have 256M ram. QuoteI strongly suggest a cpu upgradeGive me a break he has more then enough power there. I have a dedicated box for my music server and its only a 733 Celeron. It has no problems with anything. a 1.6P4 is plenty. Your problems lay elsewhere.
Interesting. Thanks for the tips. I'll see how long the rips are taking. Note that this computer also serves my SB2 (which has a very hard time while EAC is running -- if I start the SB2 playing, there's typically no problem; if I try to change anything while EAC is running, all hell breaks loose). My home computer has 512 mb of RAM and is an Athlon CPU; I forget what speed. I'm running XP. I'll see what times I'm getting, but they're long. I'll be burning tons of CDs this weekend. I have EAC so that FLAC runs after each song.
