Treating Corners
0 Members and 1 Guest are viewing this topic. Read 2064 times.
arthurs
Treating Corners
« on: 29 Dec 2005, 04:46 pm »
When treating corners, which tend to be the corners needing more treatment in a typical room, the upper at the ceiling, the lower at the floor, or split the difference and treat halfway up the wall between the two?  If forced to prioritize and do sequentially over time, where would you start?  Thanks.
DTB300
Treating Corners
« Reply #1 on: 29 Dec 2005, 04:53 pm »
Art...
Check out this forum, where Ethan Winer resides.  He is a great source for room treatments and information.
http://www.musicplayer.com/cgi-bin/ultimatebb.cgi?ubb=forum;f=26;hardset=0;start_point=0;DaysPrune=0
Say hi to Ozzie (Craig) when you get a chance there in the Big D...Dan Man from MD says hi too!!
Dan
Ethan Winer
  • Audio expert
Re: Treating Corners
« Reply #2 on: 29 Dec 2005, 05:15 pm »
Arthurs,
> which tend to be the corners needing more treatment in a typical room <
All corners are equally important. The more you treat, the flatter and tighter the low end will be. Ideally you'd treat all 12 corners (!), though I understand this is not possible for most people. :lol:
--Ethan
arthurs
Treating Corners
« Reply #3 on: 29 Dec 2005, 06:10 pm »
Thanks Ethan, but if you had four corners and four 4' traps, where would you start until you could get to the rest?  Thanks.
ctviggen
Treating Corners
« Reply #4 on: 29 Dec 2005, 06:16 pm »
One in each corner would be the best (i.e., the four corners of a room).
arthurs
Treating Corners
« Reply #5 on: 29 Dec 2005, 07:24 pm »
Thanks Bob, I assume you mean the corners at the floor?
bpape
    • Sensible Sound Solutions
Treating Corners
« Reply #6 on: 29 Dec 2005, 07:36 pm »
Corners at the floor and ceiling will react approximately the same.  Either will be preferable to the middle of the wall where you'd miss the tri-corner where the wall/wall/ceiling junction is.
ctviggen
Treating Corners
« Reply #7 on: 29 Dec 2005, 07:41 pm »
I meant at the wall-wall interface.
8thnerve
« Reply #8 on: 29 Dec 2005, 07:42 pm »
Quote from: arthurs
The tri-corners are the most important to start with.  Regarding the vertical corners of the room versus the horizontal corners at the ceiling, it depends on what attributes are most important to you.  Treating the ceiling corners will have a more pronounced effect on the reduction of echo and increasing overall clarity while the vertical corners will do more to widen and deepen your soundstage and produce a very natural midrange.  Ethan is right of course though: "treat them all!"
Nathan Loyer
Eighth Nerve
8thnerve
Treating Corners
« Reply #9 on: 29 Dec 2005, 07:45 pm »
Quote from: bpape
Usually the ceiling tri-corner is much more effective because the floor corner's return wave is broken up by furnishing in the room, and often carpet.  At the ceiling it's mostly a flat surface at all angles so the need is greater.
Nathan Loyer
Eighth Nerve
bpape
Treating Corners
« Reply #10 on: 29 Dec 2005, 09:17 pm »
Agreed - if it is usable.  Sometimes things like vaults, soffiting, vents, lights, etc. are in the way.  My point was that either the floor/wall/wall tri-corner or the ceiling/wall/wall tri-corner were preferable to halfway up on the wall/wall corner where you'd miss both.
nathanm
« Reply #11 on: 29 Dec 2005, 10:05 pm »
Quote from: Ethan Winer
--Ethan
But what if you cut some of them?
