Need advice on CD Mods.
0 Members and 1 Guest are viewing this topic. Read 2218 times.
buckeyefanandy
« on: 29 Dec 2005, 04:38 am »
I am interested in getting a upgrade on my Denon DCD 3520 with 2 new 1uf Aricaps and new burr brown op amps.  I am not very comfortable doing it myself and would like to find a good reasonable dealer or company to do this.
Any ideas of what this shoulc run me?
« Reply #1 on: 30 Dec 2005, 11:22 am »
Unless you really, really know what you're doing, I'd leave the design and installation of upgrades up to the professionals.
Warning!  Not only will a mod void the warrantee 99% of the time, there are lots of hacks out there that could easily ruin the player.
Check with them on modification packages they recommend and the time/money involved.
Note that the design time involved limits what players they work with.  I've not run across the Denon DCD 3520, so I don't know if you'll find anyone who would mod it.
audioengr
Re: Need advice on CD Mods.
« Reply #2 on: 30 Dec 2005, 06:58 pm »
Quote from: buckeyefanandy
This is kind of like doing half a tune-up on your car.  Do the plugs but not the oil or timing etc....
You should trust a modder and let him make it sound good.  I dont use Auricaps.  I have a combo that sounds much more neutral and natural.  Less sibilant.  The BB op-amps are a good idea if you use the right ones.  It is even better to eliminate the AC coupling caps and direct-couple it.
Steve N.
Rocket
« Reply #3 on: 31 Dec 2005, 03:39 am »
Hi,
Have you thought about purchasing a cheap dac and just use your denon as a dedicated transport.  A clock upgrade will probably cost over $120.00us (as an example a tent clock), plus you would have to pay to have it installed for you.
I had an old denon dcd590 and had a g&d clock installed which i really liked.
Danny @ Gr Research is selling a very inexpensive dac for $175us including shipping which i think would probably be a nice improvement at a cheap price for you.
http://www.gr-research.com/components/lite_dacs.htm
Best of luck.
Regards
Rod
Marbles
« Reply #4 on: 31 Dec 2005, 03:52 am »
I would contact Mathew Anker, www.sacdmods.com
He was pretty reasonable on his mods and he's in Columbus, OH.
I don't know if he has worked on a Denon, or if he would even work on one, but I would contact him first.
Rocket had a pretty good sugestion as well...
