blown sw-12
0 Members and 1 Guest are viewing this topic. Read 1894 times.
joegibs
blown sw-12
« on: 29 Dec 2005, 02:07 am »
i ordered a pair of these about a month ago, and have been slowly working on the enclosure for them.  i got them installed and working on christmas night, and just today got a chance to sit down and tune it and make sure everything was up to par.
i turned a song on, and turned it up to my normal listening volume and noticed a rattle coming from one sub.  i unscrewed the sub and took a better listen.  i couldnt hear it as much from the cone side, but when i put my ear between the spokes it was audible, then i put my ear to the pole vent and could hear it very clear.
before today i was pretty easy on them, i never turned the volume higher than i thought would be hard on them.  i didnt hear any distortion or anything the whole time.
the pair of subs are receiving about 400 watts rms, at 4 ohms.  they're each in a .8 cf sealed enclosure stuffed with 10 oz. of polyfil each.
i'm assuming its blown.  i cant hear it from the driver seat, only when i listen a foot away.  what shall i do?
Danny Richie
blown sw-12
« Reply #1 on: 30 Dec 2005, 02:16 am »
Just send it back to GR Research. I'll take care of it.
If yours is defective in some way then you are the lucky first.  :(
joegibs
blown sw-12
« Reply #2 on: 30 Dec 2005, 08:51 pm »
as it is right now, i can live with it, because like most people i dont sit right next to it and listen to it.  if it gets any worse or more audible, then i'll look further into whatever needs to be done.  i just wanted to let you know what's going on with it.
Danny Richie
blown sw-12
« Reply #3 on: 30 Dec 2005, 09:12 pm »
You might check and see if the wire leads are touching the cone.
joegibs
blown sw-12
« Reply #4 on: 31 Dec 2005, 12:37 am »
i made sure the wire i had running into the terminals wasnt sticking towards the cone too much, and also made sure there wasnt any tinsel lead slap going on
i dont know if i mentioned it before, but its making the noise both in the enclosure and when i pulled it out and tested it free air
