sonex installation
0 Members and 1 Guest are viewing this topic. Read 2102 times.
drphoto
sonex installation
« on: 26 Dec 2005, 07:19 pm »
Having the Sassons speakers here convinced me I need room treatment.
I found a source online for Sonex that is reasonable.
My question is this. Could I staple the foam to the wall rather than glue? I figure that way, if I ever change rooms, I won't ruin both the foam and the wall, and I can move things around to find the best spot for the panels.
I don't see why it would matter, but thought I'd ask.
BTW: my goal is to kill 'slap echo'.
warnerwh
sonex installation
« Reply #1 on: 27 Dec 2005, 07:45 am »
A light dose of spray adhesive works ok. It will come off fine if you don't over do the spray.  I think staples would be a problem.  Go to Home Depot and get some 3M spray adhesive.
Marbles
sonex installation
« Reply #2 on: 27 Dec 2005, 01:52 pm »
Doc,
You might want to consider glueing it to some inexpensive boards that you can screw into the walls.  Peg board is cheap and would work, so would any 1/8" board you can find.  Staples and tacs tend to tear the foam.
ted_b
sonex installation
« Reply #3 on: 27 Dec 2005, 02:22 pm »
I had large areas of Sonex up for over ten years (behind the front speakers).  I used the pegboard method.  I glued the sonex to the pegboard and then simply hung the pegboard on small nails throughout; the holes in the pegboard work nicely.  Then it basically lifted off after many years.  I first tired velcro and some staples, but, as Rob said, it tends to tear.  A light glue layer is perfect, and pegboard is cheap.
drphoto
sonex installation
« Reply #4 on: 27 Dec 2005, 05:36 pm »
Thanks guys. Great idea on the 'backer' boards.
drphoto
sonex installation
« Reply #5 on: 30 Dec 2005, 06:01 pm »
If the foam is mounted on peg board, would the whole thing be more effective if hung on the wall w/ an air gap behind rather than flush on the wall? Or does this sort of thing only work w/ the compressed fiberglass type traps?
BTW: Marbles. I had to take down the cheap mattress type foam you saw here before. Even though I don't have a WAF issue, I do have clients in the studio and it just looked too cheesy. I've always thought Sonex was pretty cool though.
Ethan Winer
  • Audio expert
sonex installation
« Reply #6 on: 1 Jan 2006, 05:08 pm »
> If the foam is mounted on peg board, would the whole thing be more effective if hung on the wall w/ an air gap behind rather than flush on the wall? Or does this sort of thing only work w/ the compressed fiberglass type traps? <
An air space works with foam too, but as soon as you add a rigid backing like Masonite any benefit is removed.
--Ethan
