need to get out of the seventys
0 Members and 1 Guest are viewing this topic. Read 4496 times.
ecramer
« on: 25 Dec 2005, 05:04 am »
Hello all  While i am new to audio circle i have for a long time admired of high end audio as the subject says its time to upgrade  check my system out under ecramer. i love my phase linear amp and pe amp(bought it new in the service recenly had it serviced i have  listening to it through various speakers for over 20 years)and ive pretty much decided o go with a speaker kit from Selah Audio( I do mill/ cabnet work for a living , vener is a new step for me but not to much out of my expertise and i was an electronic tech in the navy so building the crossovers is fun) i know one of there floor standers will do me right i would like to keep this project under 5k including the the speakers i have a 12  by 14 room with my computer so say 2000 fr the speakers leaves $3000 do i need to by a new amp pre amp  or can i split the 3k between the cd player new cables and a dac and maby turntable im not into home theater at all just reallly looking for the best two chanel i can afford used and new makes no diffrence to me. givr me some sugestions hey and if any of you are in 100 miles east stroudsburg pa that has a system id love to come listen to it
warnerwh
« Reply #1 on: 25 Dec 2005, 06:03 am »
You could split the money up amongst everything. Three grand will get you enough quality.  Next comes the research on what to get. You made a good choice on your speakers, congratulations.
audiojerry
« Reply #2 on: 25 Dec 2005, 06:46 am »
welcome ecramer You are off to a good start by joining audiocircle lots of friendly guys and very helpful and high quality factory direct dealers and manufacturers here Do plenty of research and ask lots of questions first $5000 can get you a very nice system If you are a cabinet maker and can do wiring work that's a great advanatge You should be able to build a great pair of speakers from kit from companies here on AC like Selah, RAW, GR Research for a grand or less I'm sure others will be able to suggest a number of other excellent AC merchants There are also some great speakers available already built like SP Technologies 2 grand opens the door to an even wider choice, but you'd be better off keeping your budget at 1 grand for the speakers You can get lots of great used equipment, but unless you already know what it sounds like in advance, that's a difficult path The most important rule is not to commit to anything unless you've heard it first or unless you can get a refund or resell it for a reasonable price The journey to building a system itself can be tremendously enjoyable and a hobby in itself Enjoying great music on a great system is the other reward!
btw, I avoided using periods in my punctuation in order to communicate on your grammatical terms  :D
« Reply #3 on: 25 Dec 2005, 11:54 am »
I came out of a 18 year long audio funk and thankfully found the internet.  Use it to full advantage.  Connect with local audiophiles and their groups.  Read all the equipment reviews you can.  Keep in mind your musical tastes and audio priorities may have changed over the years.  You'll feel like a caveman entering the modern world.
Since the 70s bass has gotten tighter and less boomy for most audiophiles.  CD playback quality has improved by leaps and bounds.  Tube pre/power amps are back in vogue.  You need to keep an eye on digitally inspired amplifier technology.  And of course PC based sourcing (improved playback of CDs burned onto a hard drive).
DIY speakers with a $5000 budget provides lots of options.  You shouldn't need to budget more than $1000 ($1500 at the max) for speakers.  About the same for CD player or audio PC with the rest towards pre/power amps.  We could affer more advice if we knew your tastes/priorities.
Marbles
« Reply #4 on: 25 Dec 2005, 01:29 pm »
Welcome to AC!!!
First, take your time and audition, audition, audition!
Second, your room (size) will limit what speakers you get, so make sure you take that into consideration.
In fact, if I were you, I might budget a big chunk of your money for room correction, like TACT 2.0 or 2.2x, and some for room treatments.
The DEQX 2.6(P) can be used as a crossover, pre, dac, and room correction.
The Tact can be used as a pre-amp and a DAC, speaker correction and room correction.
I have the Selah Tanzanites and think for your size room they would be a pretty great match.
The best bang in speaker cables that I've found is the Greg Straley Reality cables..these will run you about $250 8' pair.
I think that I would try to audition a modded Squeezbox (Red Wine or Bolder)  as a source..I would definately go computer as a source.
Best of luck to you...and again, it's the journey that's fun, so take your time.
  • Speakers....What Speakers ?
« Reply #5 on: 25 Dec 2005, 01:38 pm »
Welcome...Since your in Stroudsburg , PA.....you might check out the Mid-Atlantic Audio Circle here on AC. They have meetings...and listen to many different systems. This will give you an idea whats out there now.....and what it sounds like. Good luck.... :thumb:
    MAAC Circle link....
http://www.audiocircle.com/index.php?board=84[/list:u]
Marbles
« Reply #6 on: 25 Dec 2005, 01:46 pm »
Quote from: lonewolfny42
Stroudsburg is about mile marker 308 on I-80, he's only about 1.5 hours from The City (IIRC)  He could visit you NYC boys pretty easily....
Gordy
« Reply #7 on: 25 Dec 2005, 01:47 pm »
Welcome to Audio Circle ecramer and congrats on your first post!
continuing where Marbles left off...
Third, join up with the NY Ravers, there's a wealth of experience, opinions and tastes to be shared...
Every set of ears is different and every room reacts in its own unique way, it's up to you to decide what's the best combination for you.  As mentioned above, buying used is a great way to broaden your experience base, as would be signing up for some of the "tours" that happen here from time to time.  It'll take some time to build a system that truely works as a whole, but the journey is a blast, enjoy it!
« Reply #8 on: 25 Dec 2005, 01:51 pm »
Quote from: Marbles
Stroudsburg is about exit 303 on I-80, he's only about 2 hours from The City (IIRC)  He could visit you NYC boys pretty easily....
Your right, I was thinking by Reading :? (no sleep :lol: )...first stop would be at Phil's or JoshK's heading east.....70 to 80 mile trip... 8)
PhilNYC
« Reply #9 on: 25 Dec 2005, 02:23 pm »
Check out the NY Audio Rave here...: http://www.audiocircle.com/index.php?board=62
And here's the specific meeting hosted by JoshK when Rick Craig (Selah Audio) brought his speakers for the Rave to try out:
http://www.audiocircle.com/index.php?topic=16967
rosconey
« Reply #10 on: 25 Dec 2005, 03:11 pm »
i have a pair of custom design speakers by rick  :mrgreen:
they play real well with my odyssey amps and pre
might want to give klaus a call-he had some garage sale stuff a few weeks ago-
im in syracuse-not sure if thats within your 100 mile window
what ever you decide you can find it here :mrgreen: at ac
audiojerry
« Reply #11 on: 25 Dec 2005, 05:29 pm »
I always marvel at the rapid response and willingness of fellow AC members to help out a newcomer.
Toast to all!   :beer:
I wonder if we've scared ecramer off with our zeal.
It is Christmas Day, though.
Season's Greetings to all!
Jon L
Re: need to get out of the seventys
« Reply #12 on: 25 Dec 2005, 06:08 pm »
Quote from: ecramer
Hello all  While i am new to audio circle i have for a long time admired of high end audio as the subject says its time to upgrade  check my system out under ecramer. i love my phase linear amp and pe amp(bought it new in the service recenly had it serviced i have  listening to it through various speakers for over 20 years)and ive pretty much decided o go with a speaker kit from Selah Audio( I do mill/ cabnet work for a living , vener is a new step for me but not to much out of my expertise and i was an ele ...
Welcome to the Circle.  I am so envious of people who have woodworking skills to build their own speakers.  Selah is a good choice, so I would build the speakers first, then audition various front-end and pre/amp on your speakers in your room.
It is my strong opinion that THE thing that will make or break you as an audiophile and music lover is figuring out what your tastes are.  I would pretty much ignore advices/audiophiles/dealers who keep going on about stuff like "absolute neutrality" "sounds like real music played in real space" , etc, etc.  After you pay the money, fight the good fight, and shed the sweat, it really comes down to whether your system fits your music/tastes and whether you can enjoy your music in your room, not whether Harry Pearson can enjoy the music on your system.
Rocket
« Reply #13 on: 26 Dec 2005, 02:56 am »
Hi,
That statement is about the best advice anyone can say to you.  Demo as much gear as you can and let your own ears decide what you want to purchase.
Regards
Rod
ecramer
« Reply #14 on: 27 Dec 2005, 02:18 am »
My sister actually lives in brooklyn going in to visit her in feb. for het 50th birthday really not that far but i hat driving into the city to much country boy in me lol
Stroudsburg is about mile marker 308 on I-80, he's only about 1.5 hours from The City (IIRC)  He could visit you NYC boys pretty easily....[/quote]
ecramer
« Reply #15 on: 27 Dec 2005, 02:33 am »
I would like to thank all of you for the warm welcome makes me feel right at home. been a couple of busy days i hope every one has had a good and joyious holiday me pesonaly had a little to much wine over the weekend but youl have this in a small town.
Season's Greetings to all![/quote]
ecramer
« Reply #16 on: 27 Dec 2005, 03:40 am »
Regards
I would really like to demo a rotel rcd-1072 and are thiere any thoughts on the Onix CD-2 CD from av-123 although i really hate to ask a judgment on equipment when the cmpany have thier owh circle here
ecramer
« Reply #17 on: 27 Dec 2005, 01:22 pm »
Quote from: rosconey
Heading up to Lake Senica on the 14 of jan. to do some wine taisting but proably wont have any time to do much audio evaluaation.
ecramer
test
« Reply #18 on: 28 Dec 2005, 06:32 am »
is this working
