Mills MRA-5 5W resistor ok for R21 in Classic Cornet?
0 Members and 1 Guest are viewing this topic. Read 2518 times.
markmaloof
Now everything is here, and once the next few Holidays are over, I'll be back in town to solder in the transformer connections, RCAs and Lundahl step-ups, and then I'll be playing the Cornet.  I had ended up ordering some Mills resistors (along with Rikens), did not realize how small the Mills are!  I'm using a 2 ohm 5 watt Mills MRA-5 for R21 (2ohms because I've done the CCS mod.)  The body of the Mills is at least a third the size of the usual white ceramic power resistors, like the one I used for R22 (just a run of the mill from Mouser.)  The Mills MRA-5 is rated MRA-5 (5 watt power rating), and according to Sonic Craft's site, will "handle overloads 5X its power rating (25 watts) for 5 seconds with operating voltages up to 500 VAC."  The body has an alumina ceramic core with Nickel-Copper element (it that means anything.)  I guess the very small size of the resistor (when compared to the usaul white ceramic power resistor) has me feeling a little cautions, but with the specs given for it, I should be ok in R21, no?
And....Happy Holidays to all!
hagtech
« Reply #1 on: 23 Dec 2005, 11:38 pm »
I tell you what, solder it about 1/4 inch off the board.  The resistor can handle the extra heat, the board cannot.  At 90C the fiberglass starts to yellow.
jh :)
markmaloof
« Reply #2 on: 24 Dec 2005, 12:27 am »
Thanks Jim.  I also got confimation at Audioasylum that all would be well.  I soldered the resistor closer to a 1/2 inch above the board, plenty of space.  The other power resistor, the .22 ohm one, is a standard withe ceramic bodied Xicon, that has less space (a little more than 1/8th inch above the board), that should hopefully be enough space to allow some air flow around the resistor and not cause any scorching of the board, right?
