One channel of 4B-ST is dead?
0 Members and 1 Guest are viewing this topic. Read 2340 times.
fengzeiss
« on: 22 Dec 2005, 07:27 pm »
My 4B-ST have served me well for over 6 years. But someday, one of the channel can't make sound suddenly. The pre-amp functions normally. What happened to my 4B-ST? The fuse seemed O.K. Thanks for any opinion!!
bsmith15
« Reply #1 on: 22 Dec 2005, 08:24 pm »
I am not at all an expert on anything electricial; but several years ago I had the right channel stop functioning in a Rotel amp I had.  I checked the fuse and it looked to be in perfect condition so I thought it must be something more serious and took the amp in for repair....sure enough all it needed was a new fuse.  I would change the fuse if you have one just to be sure.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 23 Dec 2005, 01:02 pm »
HI,
Is the right channel LED out?
james
fengzeiss
« Reply #3 on: 23 Dec 2005, 05:06 pm »
Two led appeared green , it seems function well. Will it be helpful if I switch the button(unbalanced-balanced and individual-bridged) repeatedly, supposed it is due to switch contact problem?
« Reply #4 on: 23 Dec 2005, 05:30 pm »
HI,
So it is working OK now?
james
doorman
« Reply #5 on: 23 Dec 2005, 07:01 pm »
Luckily, they have a 20 yr. warranty
fengzeiss
« Reply #6 on: 24 Dec 2005, 11:11 am »
Good News:
The problems is solved. I switch the individual-bridged and balanced-unbalanced button repeatedly. It did work. The sound come back.
