0 Members and 1 Guest are viewing this topic. Read 4006 times.
Either way, such a series-connected, dual-sub setup powered by a single amp would almost certainly require long runs of cable. I would start to worry about things like the extra cable resistance, variable timing delays, and other such issues. Even if these turn out not to be a problem, wiring such a setup will probably be inconvenient at the very least - even if 1000W is enough to power the combined subs.
I thought the 215 was 8ohm load?
