input/output pins?
0 Members and 1 Guest are viewing this topic. Read 1782 times.
gorgeousgeorge
input/output pins?
« on: 20 Dec 2005, 08:44 am »
hello all,
this might be a silly question, but im going to ask anyway and plead absolute ignorance as my excuse.
what is the best way to connect the input/output wires to these pins? are there plugs that i can use or just solder straight onto them?
Cheers, George :oops:
AKSA
input/output pins?
« Reply #1 on: 20 Dec 2005, 11:26 am »
George,
Soldering is best;  they are silver pins, very easy to solder, and highly conductive.
Hugh
gorgeousgeorge
input/output pins?
« Reply #2 on: 20 Dec 2005, 07:42 pm »
Thanks Hugh,
very nearly finished Aksa and TLP, wont be long now and my ears will be in audio bliss.
Cheers, george
SamL
input/output pins?
« Reply #3 on: 4 Jan 2006, 01:38 am »
Quote from: AKSA
George,
Hugh
Hi Hugh,
You should add the word 'silver' in your part list. I though they are just normal steel pin and throw them into the bin.
AKSA
input/output pins?
« Reply #4 on: 4 Jan 2006, 01:39 am »
Hi Sam,
 :lol:  :lol:  :lol:  :lol:
You got more quality than you expected!!
Hugh
Seano
input/output pins?
« Reply #5 on: 4 Jan 2006, 06:45 am »
I'm with Sam!
I ignored them and soldered the Cat5 direct to the board.....
Geoff-AU
input/output pins?
« Reply #6 on: 4 Jan 2006, 07:34 am »
well, soldering directly to the board is still 1 less junction and that's always going to be better.  but there's no harm in using them for convenience since they are good quality :)
PSP
I went back to using the pins
« Reply #7 on: 4 Jan 2006, 03:14 pm »
When building my GK-1 I ignored the pins and soldered all the I/O wires directly to the board... and then in subsequent cap-tweaking work I found that I was starting to lift some of the PCB pads to which I had soldered those direct wires.  For the long-term life of the GK-1, I put those pcb pins back in.  You can safely solder/desolder to the pins dozens of times with no effect on the PCB pads.
I might (or might not) be able to hear one more solder joint, but I can very definitely hear the sweet music that the GK-1 makes and (IMO) it's too much to risk for a small/marginal/possibly nonexistent benefit.
Peter
