4B-SST driving Thiels?
0 Members and 1 Guest are viewing this topic. Read 1574 times.
pistolpete
« on: 20 Dec 2005, 04:36 am »
Anyone using Bryston with Thiels?  I have a 4B-SST and want a pair of Thiels (maybe the new CS3.7).
Pete
Phil A
« Reply #1 on: 20 Dec 2005, 03:22 pm »
I used the 3-channel (6BSST) to drive 7.2s in a big room.  I now use the amp for the center and surrounds and a 14BSST for the 7.2s.  Heat wise the 4BSST (or the 6B) won't have as many problems as the 15 amp version of the 14BSST.
pistolpete
« Reply #2 on: 20 Dec 2005, 03:34 pm »
Hey Phil, I see you are somewhat close to me(Baltimore).  What stores do you visit and like best in your area?  I am asking because I have an issue with the local Thiel dealer (SNOB!).
Also, what preamp do you like with the Brystons?
Pete
Phil A
« Reply #3 on: 20 Dec 2005, 09:09 pm »
Pete, I got both of my Bryston amps very lightly used (both just under a yr. old) within the last couple of yrs.  I use a Bryston SP1.7 as a preamp.  I usually shop at Gifted Listener Audio in Centreville, VA.  I got the SP1.7 and my Thiels there.  They don't carry every model and I constantly rib them to carry more Bryston, Thiel and Ayre vs. what they have now (they finally got Maggie 20.1s so some of my pestering helped), but it is small store with outstanding service.  My friend used to work there for about 5 yrs. part time and I did virtually all of his deliveries/installs with him.  I started out as more into HT but then after dropping off so many high end systems I 'd come home and while my system did music very well for a HT, it was not up to snuff with music only systems.
