looking for advice and recommendations
0 Members and 1 Guest are viewing this topic. Read 1307 times.
jcrane
« on: 18 Dec 2005, 03:46 am »
Well I have decided I want a DAC. Problem is I don't know a damn thing about them (other than what they do and how they work) or maybe I shouuld say I don't know a damn thing about who makes them. Since I trust your guys knowledge can you recommend some DACs? Used is fine, ability to be modded is ok. Like to stay under 400 bucks, but cheaper would be better :lol:
I know this is a small amount compared to most of your budgets, but hey, I have other things to buy too, I mean I am a HOME THEATER guy first!
If can recommend brands/models or if you see one posted on Audiogon or here, can you PM/Email me or post here?
THanks GUYS
Jamie
bpape
    • Sensible Sound Solutions
« Reply #1 on: 21 Dec 2005, 04:56 pm »
Jamie,
I asked some similar questions the other night.  The one that came up as a possible answer was the Scott Nixon DAC.  Once in a while you'll see one pop up used.
I'm an HT guy too but also do a lot of music listening in my room and upstairs.  I just bought a SB2 and was thinking of doing the digital mod on it and adding the Nixon DAC for my system upstairs to try it out.
Bryan
jcrane
« Reply #2 on: 21 Dec 2005, 07:24 pm »
Thanks for the tip!
Scott offered some advice too, so I am trying to sort out everything and will make a choice after the new year.
I am wanting one for my SB3, as I am finding it hard to listen to the CD player anymore, just too easy with the SB3 to switch albums when I want and on the fly too!
I am now thinking I want a SB3 for my bedroom and my headphone setup. I would like to get the one I have for my 2ch setup modded but really I am pretty happy at the moment with it stock.
Bill Baker
    • Musica Bella Audio
« Reply #3 on: 21 Dec 2005, 07:53 pm »
If you want a good, affordable DAC, look at a used Adcom. I found this to be an exceptional piece for the money (used).
 Just another suggestion.
