Anyone tried HSU hi-pass filter?
0 Members and 1 Guest are viewing this topic. Read 1913 times.
drphoto
« on: 1 May 2003, 01:12 am »
Just wondering how it sounds. The ACI passive line level h-pass filters didn't work in my system....muffled the sound too much.
I like the idea of hi-passing my Maggies, and if could be done on the cheap...all the better.
audiojerry
« Reply #1 on: 1 May 2003, 02:46 pm »
not familiar with either the ACI or the HSU, but was wondering if the filters are caps built into a short male/female RCA or XLR cable?
I've done this in the past and felt they work much better than a high pass after the amp stage. A high qulaity cap must be used; the most difficult part is getting the right value cap to match the amp impedence.
Bwanagreg
« Reply #2 on: 1 May 2003, 04:04 pm »
I just bought a pair of the ACI filters - I'm awaiting a Rava sub before I try them out.
The filters are built into a barrel-type connector, with male and female rca plugs on either end. I believe they also load the capacitor with additional resistance to make the cutoff more consistent across different amps, but I may be wrong. The reason I say this is that I have been told to expect to need a higher preamp setting to achive the same power level from the amp.
I'll post comment when my Rava shows up in (hopefully) 2-3 weeks.
audiojerry
« Reply #3 on: 1 May 2003, 06:18 pm »
Drphoto, if there is a resistor in ACI highpass, it may be the culprit.
There is a formula for calculating cap value by supplying desired cutoff frequency and amp impedence to achieve a 1st order rolloff (6db/octave):
C = 1/(2*3.14159*f*R)
where
C is capacitance
f is frequency in Hertz
R is the input impedance in ohms
I don't know how this was derived
Bwanagreg
« Reply #4 on: 1 May 2003, 06:26 pm »
From the ACI site:
ACI Filters are 1st Order, (6db/oct), and  resistively loaded to allow use with virtually any power amplifier. Choose between two crossover frequencies of: 85Hz or 65Hz.
Den
« Reply #5 on: 3 May 2003, 09:40 am »
http://www.hsustore.com/high-pass.html
I haven't heard this 12 dB/oct filter, but the 24db/oct filter in the amp of my Hsu 12v is worse than the ACI passive filter.
Val
« Reply #6 on: 3 May 2003, 11:42 am »
I have listened to the High End Crossover Hsu sells for around $450 and it is as transparent as anything out there, I would recommend it without a doubt. Don't know about the rest.
