0 Members and 1 Guest are viewing this topic. Read 4412 times.
Sounds like the motherboard got fried by a spike or maybe the power supply. Unplug everything(mouse, keyboard etc..) except for the monitor and see what happens.
Turn computer off and unplug, allow to cool overnight. Then plug it back in and try a boot.If it doesn't come back, kiss it goodbye and leave it on the curb with a sign saying "some parts may still be usable".You could try getting it repaired, but I've been that route and unless it was brand new/under warranty, it's better to buy a cheap replacement. Of course, if there was anything on there you really, really cared about... well, you can get the data back, but it's rarely cheap.Having the disk ...
Now before labelling this PC as "junk", try a few of things.- Like someone mentioned, listen to any beeping noise when the PC tries to boot up. Short 2 beeps usually means that the video card is not seated right. Or it would be that the RAM modules are not seated right.- Do you hear any hard drive access sound?- Remove the PC cover, and see if the CPU fan comes on when u try to boot it up.- And this is a audio group ... you'll have much better chance at trouble shooting ur PC if u post ur problems at forums like anandtech.com.Let us know what happens.
What does a "hard drive access sound" sound like?I did turn it on with the cover off, but wasn't really listening for beeps. The fan did turn on. I'll try it again and listen for beeps tonight or tomorrow.
'd never throw away a computer without removing the hard drive first, for privacy reasons. If you can't transfer the data from the hard drive to a new computer there are pay services that can help. If you must throw out the hard drive, take a hammer and smash it up first. That insures your privacy and feels good, too.
The beeps are generally pretty loud and not something you notmally hear during system startup, you've have noticed if it started beeping.Hard drives (small metal boxes abut the size of an overgrown deck of playing cards) make a faint whrrring when they start up - put your ear near the disk because it can be hard to hear over the fans otherwise. Then, as the computer begins to use the disk, it makes quiet clicks and thunks. It will do this a lot if Windows is booting, and once or not at all if the machin ...
pugs, please don't take these questions as insulting, but your first post didn't mention doing anything to turn the computer back on except plugging it in. Are you sure you pushed the on/off button? Also, check to see if your computer has a power switch on the back near where the plug goes. If so, that switch should be pushed so that the "I" is down and the "O" is up. Finally, check your powerstrip to make sure it is turned on, and check your outlet-plug a light in it to make sure it works.From your ...
Do you have access to another computer? If so, connect your monitor to that computer. If your monitor works, the problem's with your PC. Take the video card out of the good PC and plug it into your PC and plug your monitor into the new video card (take out your old video card). Turn on your PC and see what happens. If nothing, then you could take the old video card and put it into the new computer. If the old video card works, you've ruled out one more thing. From here on out, it gets a bit harder. ...
