SPDIF output from my Mac?
0 Members and 1 Guest are viewing this topic. Read 2980 times.
studley
« on: 4 Dec 2005, 01:50 pm »
I want to use an M-Audio Firewire Audiophile to get a SPDIF signal from my ibook G4 to an external DAC.  I am reliably informed that I can set the ibook audio output to SPDIF by going into Utilities> Audio/MIDI and choosing the SPDIF option. However, although my ibook is recognising my M-Audio device's existence and I can set it as the audio output device, I can't find any SPDIF output option to select.
I have asked this question on the Apple discussion forum but had no replies.
Can anyone help?
konut
« Reply #1 on: 5 Dec 2005, 02:40 am »
I'm pretty sure your iBook has no SPDIF out option. Your M-Audio device hooks up to your firewire port and has its own DAC. Are you looking to get a SPDIF out for connection to a different DAC?
studley
« Reply #2 on: 5 Dec 2005, 10:11 am »
Konut
Thanks for replying.
Yes, I want to use a (better) external DAC rather than the one in the M-Audio device.   Hence I need to get the ibook to send a spdif signal through the firewire lead.
M-Audio say this can be done with an ibook and  their advice suggest I should find a spdif output option in the speaker configuration tab in  Utilities>Audio/MIDI but I am not seeing any such option.
Watson
« Reply #3 on: 5 Dec 2005, 11:12 am »
Isn't the M-Audio Firewire's S/PDIF output active all the time?  Try it.  You may not need to enable anything in software to get it to work.
studley
« Reply #4 on: 5 Dec 2005, 12:32 pm »
Watson
Bit of a crossed wire (ha ha) - its not the spdif output from the Audiophile I'm having trouble setting up, its the spdif output from the ibook.
Watson
« Reply #5 on: 5 Dec 2005, 01:03 pm »
The iBook has no S/PDIF output.  Some of the Powerbooks do.
philipp
« Reply #6 on: 5 Dec 2005, 03:24 pm »
I'm confused. I thought all USB and Firewire transmission, like S/PDIF, was digital until it encountered a DAC of some sort. Am I wrong?
bmed
« Reply #7 on: 5 Dec 2005, 05:02 pm »
USB is used to get the signal out of your computer since it has no digital out.  Devices like the  M-audio ones then allow you to use the standard S/PDIF output from the M-audio device to the DAC of your choice.  There is no S/PDIF out from your ibook.  You will only need to designate the output as the M-audio USB or firewire.  Gordon Rankin has a really good write-up on this topic on his website.
  http://www.wavelengthaudio.com/usbdac.html
Brad
philipp
« Reply #8 on: 5 Dec 2005, 05:51 pm »
Thanks for the link Brad, that helps a lot. Time to select that error correction box in iTunes!
I also found other products that will convert the USB out of a computer to S/PDIF:
http://www.empiricalaudio.com/frComputer_Audio.html
studley
« Reply #9 on: 5 Dec 2005, 07:25 pm »
Thanks for all the replies.  Having got through to technical support at M Audio by telephone I now have the answer!
To get a spdif signal out through the firewire (or USB) port you go to utilities>Audio/MIDI>speaker configuration and then select channels 5 and 6. That's it!
