0 Members and 1 Guest are viewing this topic. Read 4720 times.
I totally don't understand the 480i being the best solution over HDMI, unless that is for displays with a lower native resolution.
wshuff - I understand why DVI/HMDI will be better than analog component connection, but why specifically 480i? Why not something in a higher resolution?
Calibration- This one I know is needed on every new set, my question is should I buy a do it yourself disk such as Avia or should I hire a pro to do it? Is hiring someone overkill? My TV is a Sony KD-34XS955 CRT. Any thoughts welcome.
Q,All I know about the Mosquito is what I've read in a few threads on AVS. I'm sure that you've seen the same ones. Still, I'll take a shot.My only experience with video processing has been with the CS-1 I got a few months ago and then with the processing built into my DVD players. I found that the Sil504 chip in my Denon 2900, and the Faroudja in my Pannie RP82 made a noticeable difference compared to the chips used in my previous DVD players. I now have an Oppo, which uses the Faroudja chip, o ...
