Monolithic mods
0 Members and 1 Guest are viewing this topic. Read 3009 times.
dogberry
Monolithic mods
« on: 28 Apr 2003, 11:09 pm »
Are you doing any mods to the Monolithic phono stage or PS?
If so, what do you anticipate the changes in sound to be?  Cost?
Thanks, Dan.
modwright
    • ModWright Instruments
Monolithic Mods
« Reply #1 on: 27 May 2003, 05:56 pm »
Hi, sorry for the late response...
We ARE offering mods for the PS-1 and HC-1.
The mods for the PS-1 are $250 and include the following:
Upgraded op-amps.
Upgraded key input signal path resistors to Visahys.
Upgraded power supply filtering.
Upgraded power supply decoupling with Black Gate capacitors.
HC-1 Mods are $200 and include the following:
Install a single Bybee filter per channel at the transformer secondary voltages serving the dual mono circuits in the PS-1.  This significantly cleans up the supply voltage to the PS-1 and lowers the noise floor.
Dan W.
dogberry
Channel Islands
« Reply #2 on: 31 May 2003, 05:12 pm »
Is the CI power supply similar to the Monolithic?  I have the CI DAC and will be getting the CI power supply....
Thanks, Dan.
modwright
CI Power Supply
« Reply #3 on: 1 Jun 2003, 01:59 am »
The CI power supply for the PP-1 or VDA-1 will NOT work with the Monolithic PS-1.  I am not sure if this answers your question.
Dan
