0 Members and 1 Guest are viewing this topic. Read 5086 times.
... I've ripped/tagged 2300+ CD's so I pretty much have a system. I also use flactester to make sure the file are good before I move them to my drives and backup to DVD-RW.
I use Mediamonkey first to find the artist/album - MM put associates songs names with track # automatically
It was my understanding that this was not a problem for Slimserver, that it could recognize standard directory/file names for playback and playlist use.
"That's it - lots of work but Slimserver depends on tags to work properly."Hi Tony,I've been contemplating a move to SB3. Over the last several months I have been building a WAV library from LPs I have recorded on to my hard drive via a Xitel USB device. Xitel provides an editing program to turn the WAV file into seperate tracks/WAVs, but I don't believe I have any Tags for these. It was my understanding that this was not a problem for Slimserver, that it could recognize standard directory/file names for playback and playlist use. Is this not true?Thanks,Karl
Quote from: tdangeloI use Mediamonkey first to find the artist/album - MM put associates songs names with track # automaticallyTony,As others here, I am trying to find my own way of doing this. With Mediamonkey, do you still use the related tabs in EAC? When exactly do you start using Mediamonkey? I am thinking of freedb and also of the filename tab (%T\%N, etc.) and the ID3 tags. I haven't yet tried Mediamonkey or Tag&Rename.One thing I am already sure of is not using AccurateRip any more. Enough stress already without it!Thanks
Could you clarify the statement that Slimserver depends on tags to work properly?Does that mean that if you don't use tags slimserver won't work properly or that if your tags are not properly done slimserver won't work.I am using Slimserver with Softsqueeze (waiting for my SB3) and don't use tags at all and it works fine.To be honest the reason I am not using tags is because I have no idea what a tag even is. Why isn't a tag just a new word for a filename?
