270BX to 370BX - significant upgrade for Cornet Classic?
0 Members and 1 Guest are viewing this topic. Read 1846 times.
queg
I recently did the CCS upgrade in my Cornet Classic and also replaced C5 with Vcaps (wow!).
I'm having fun with this, so now I'm wondering if I should replace the Hammond 270BX with the 370BX.
Is this a significant, obviously audible upgrade?
Is it difficult?
SHIF
« Reply #1 on: 2 Dec 2005, 06:27 am »
I upgraded to the 370BX after my 270BX melted-down!  Glad I had a fuse on the A/C mains when the old tranny died.
It is not a difficult installation, in fact it's exactly the same, you just have a few unused leads to tie off.
-S
BobM
« Reply #2 on: 2 Dec 2005, 02:00 pm »
But what is the sonic difference?
I'm also potentially interested in this swap, but for a different reason. My Coronet buzzes and I've been told that it could be due to higher voltages than the 270 is rated for. I could install a resistor to drop them down, ot swap it out for th 370.
If there's a sonic improvement with the 370 then my decision is obviously easier.
Enjoy,
Bob
queg
« Reply #3 on: 2 Dec 2005, 09:30 pm »
Due to lack of response regarding the question of a sonic difference between the two, I'll assume there is none and spend the money on records.
I guess if it ain't broke I shouldn't fix it.
