Titan
m_l
Titan
« on: 28 Nov 2005, 02:50 am »
Hello,
I bought a full ACI system for HT and 2ch, a few years back. Yesterday I  was cleaning Titan cabinet and noticed that the amp was warm to the touch and the led was showing it was on. I checked back few hours later and it was still on. It used to turn it self off after a little while. Has anybody had the same problem?  Should I turn the amp off manually after each use? I'm just worried that the amp being on all the time  will slowly get damaged. Any thoughts or comments will be helpful.
Mike
Mike Dzurko
Titan
« Reply #1 on: 28 Nov 2005, 12:21 pm »
Mike:
Nothing to worry about, the amp is meant to stay on 24/7. It is only burning a few watts at idle with no input. If leaving for vacation, etc. I'd say turn it off, otherwise just leave it on.
m_l
Titan
« Reply #2 on: 28 Nov 2005, 05:11 pm »
ok Thank You
