cooling fan for diy class a 15w amp
0 Members and 1 Guest are viewing this topic. Read 1885 times.
freo
« on: 26 Nov 2005, 07:47 am »
Hello
I have finished a small project, a 15w class a amp with seperate power supply. The power supply is getting quite hot so I installed a 12v fan, only problem is the fan is noisy. Any suggestions, has anyone any idea what temp the heatsink behind the transistors should be. I thought about driling holes in the fins and running copper wires to another heatsink to difuse the heat, do you think this will work any suggestions welcome, by the way the amp with my bottlehead pre sounds great
Regards Roger
bluesky
« Reply #1 on: 26 Nov 2005, 10:44 am »
Hi Roger
I have built this kit as too, well actually two sets of them!  One is built with standard parts and the other set has all "premium boutique parts", the idea being that as this amp has such low THD I should be able to hear the difference (if any) of these parts and so I can decide for myself whether or not to use such things in future projects.
Getting back to your thread topic, I was in Jaycar just this afternoon looking at possible alternatives to the heat produced by this amp set up, don't forget the power supply either, as I have read that this also generates a lot of heat!
Jaycar has some nesting heatsinks that can be joined together, and there are some fans available with very low sound levels.  My thoughts are to get a set of these and try to encase them within the chassis with some sort of casing that will reduce the noise levels of the fan by having the air input and output facing away from the listening position and having a small aluminium shield between the listening position and the inlet/outlet of the cooling fan. I don't know how effective this would be but would imagine that with a low noise fan and appropriate positioning of the shielding the noise level would not be intrusive.
It's worth a try!  Let me know what ideas you can come up with!
Cheers
Bluesky
jaudio
Re: cooling fan for diy class a 15w amp
« Reply #2 on: 26 Nov 2005, 12:26 pm »
Quote from: freo
Hello
Regards Roger
If you are running the fan at 12volt, add a resistor to lower the voltage from 12volt to 6volt.
freo
using resistor to lower the voltageof 12v fan
« Reply #3 on: 26 Nov 2005, 01:43 pm »
Stupid question I know but where would I place the resistor and what value would I use? I have a 12v regulator with 3 pins do I put the resistor across the 2 outside pins?
Regards and thank you in advance Roger
JoshK
« Reply #4 on: 26 Nov 2005, 05:50 pm »
I think you want to put the resistors in series with the "hot" leg, which ever that one might be.  This will drop the voltage prior to the fan.  Use good 'ol Ohms law V = IR to calculate the appropriate resistor value, or just experiment with a couple different values till you get something you want.
jaudio
« Reply #5 on: 27 Nov 2005, 12:24 pm »
Quote from: JoshK
Right    Just connect the resistor to the fan's red wire.
Quote from: JoshK
After you find the right resistor,Check it by turn the power on and off a couple of times. If there is to much resistance the fan will not always start.
jaudio
« Reply #6 on: 27 Nov 2005, 12:25 pm »
Quote from: JoshK
Right.    Just connect the resistor to the fan's red wire.
Quote from: JoshK
