belkins pureav line conditioners
0 Members and 1 Guest are viewing this topic. Read 1940 times.
marvda1
  • freelance reviewer: The Sound Advocate
« on: 24 Nov 2005, 12:20 am »
anyone have any experience with these line conditioners and if you do how do they sound? you can get one on the net that retails for $750 for about $150.
warnerwh
« Reply #1 on: 24 Nov 2005, 06:29 am »
I'm sure they work well. Belkin has been doing this for a long time.  Personally I like the Powervar and Oneac commercial grade line conditioners. Not as pretty but very effect, I feel safe knowing that some of my gear is plugged into one. I do also use an inexpensive Tripp Lite for some gear that I don't care about as much, think it cost about 70 bucks.
Where's this conditioner on the net you are referring to?
marvda1
murphy11
« Reply #3 on: 24 Nov 2005, 12:35 pm »
You can also the the PF60 for $199 at Digitally Unique (now on backorder) http://av123forum.com/showthread.php?s=&threadid=11209
murphy11
« Reply #4 on: 24 Nov 2005, 12:41 pm »
Edit - doesn't look llike the PF60 is listed anymore, but the have the PF40 listed as in stock at $144.
Charles Calkins
« Reply #5 on: 24 Nov 2005, 01:04 pm »
I bought my PF40 at thetwistergroup.com. Looks and works fine. The music doesn't sound any better. The TV picture is a wee bit better. It's just another bells and whistles gizmo that we absolutely must have!!!
                                   Cheers
                                   Charlie
