External subwoofer connection with B100 SST?
0 Members and 1 Guest are viewing this topic. Read 1287 times.
jgman
« on: 23 Nov 2005, 02:41 am »
Need to know the best way to connect my external subwoofer crossover to my B100 integrated amplifier.  My thought is to run the preouts from the B100 to the crossover and than run the hi-pass from the crossover back to the B100 via the main-ins.  However, I was told by doing this I would be running the high end through the inferior preamp of the crossover rather than the B100.  Any thoughts or advice on how to configure would be greatly appreciated.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #1 on: 23 Nov 2005, 06:17 pm »
Hi jgman,
Yes you would be going through the low quality electronics in the sub woofer if you used it the way you say.
james
