Are there any class D headphone amps.
0 Members and 1 Guest are viewing this topic. Read 2984 times.
DaveX
« on: 21 Nov 2005, 10:05 pm »
I want a headphone amp that sounds as good as the Channel Islands D200 monoblocks. Is there any class D headphone amps out there. Thanks.
Charles Calkins
« Reply #1 on: 21 Nov 2005, 11:58 pm »
If you found one it would probably cost $$$$$$$$$$$$$$$$$$$$$$$$$$$. Or a little more.
                                     Cheers
                                     Charlie
JeffB
« Reply #2 on: 22 Nov 2005, 12:01 am »
I believe Red Wine Audio can outfit a Clari-T as a headphone amplifier.
I would talk to Vinnie about it.
randytsuch
« Reply #3 on: 22 Nov 2005, 12:58 am »
You would probably need to rewire you cans, unless the have AKG 1000's.
You need to have seperate grounds, and not a shared ground that is standard with headphones, to use a sonic impact type amp.
Randy
lbo
« Reply #4 on: 22 Nov 2005, 01:25 am »
why does it have to be class D?
Class D is mostly for efficiency and compactness (high power factor). Headphone amps are low-power devices so there really isn't as much of a need there as in say a 1kw power amp for class d.
DaveX
« Reply #5 on: 22 Nov 2005, 02:06 am »
OK, let me rephrase the question.
What headphone amp would bring me the closest to the sound quality of the Channel Islands D200's monoblock power amplifiers. Thanks.
CIAudio
    • http://www.ciaudio.com
« Reply #6 on: 22 Nov 2005, 02:13 am »
a CIAudio VHP•1/VAC•1 combo  :D
