0 Members and 1 Guest are viewing this topic. Read 3441 times.
For reasons explained above, LEDE specs will be strictly followed for all surfaces of the front third of the room & all remaining wall/ceiling surfaces.
That was my general consensus. I was curious to read opposed opinions if any existed. One obvious source, a two channel specialty manufacturer, of course said LEDE all the way. He might be right & he might be an excellent 8.1 info source, but I'm looking for the cheaper more convenient way out, as usual.
If you want to use 8 channels there is no use of the LEDE setup, go for a fully damped room front and back.The half baked idea behind LEDE is that stereo doesn't and can't have enough ambience recorded, so you need a live room for playback, but the early reflection structure of your room does not match the original venue, and it is rather destructive than helping, so you have to damp those. LEDE just successfully combined the disadvantages BTW DPL is not the best way to get the extra channels. You can not "extract" ambience from stereo signal with steering or matrixing.
The front side axis speaker area will be damped. The side dipoles rely on reflected sound, & the rears are pointed at the ceiling for diffusion. This would seem to contraindicate damping for those speakers.
