Question: Connecting a Behringer DEQ2496 and Denon DCM-370?
0 Members and 1 Guest are viewing this topic. Read 888 times.
Sintz
Hello all!
I have a quick question that hopefully one of you knowledgable folks can help me out with:
Does anyone know if I can connect the digital coax output from the Denon DCM-370 to the Behringer DEQ2496?
I'm currently using a Denon DCM-370's unbalanced/RCA outputs into a Parasound Halo P3 preamp, then unbalanced/RCA to my AKSA100 amplifier.
I've been experimenting with room equalization using an Alesis MEQ230 1/3 octave analog eq and have been able to significantly improve overall sound in my irregularly shaped listening room, but am left with some unwanted noise with the Alesis in the chain. :(
I've been looking at the possibility of using a Behringer DEQ2496, but wanted to make sure I can use a digital connection using the Coxial Digital output of the Denon DCM-370.
What are my options?
:stupid:
Any help would be greatly appreciated.
Thanks so much in advance!
Sintz
Got it.
« Reply #1 on: 20 Nov 2005, 07:49 pm »
Thanks to 'warnerwh', 'jhenderson010759',  and 'spons' for the excellent suggestions.
I've purchased a Mercenary Audio S/PDIF to AES/EBU transformer (will conver from 75-ohm S/PDIF to 110-ohm AES/EBU). This seemed to be the most cost-effective solution.
Thanks again.
