Nemesis
0 Members and 1 Guest are viewing this topic. Read 1386 times.
BradSD
Nemesis
« on: 16 Nov 2005, 10:29 pm »
I googled the Nemesis center channel speaker hoping to find any reviews/comments on sound and didn't find a thing.
I was wondering if anyone here has it, or has had a chance to audition one?
Right now I have the Polk LSiC playing the center roll.
Any feedback would be appreciated.
Brad
byteme
Nemesis
« Reply #1 on: 16 Nov 2005, 11:00 pm »
What's the rest of the setup look like?  Is it Polk all around?
The nemesis is a PERFECT match for the other Odyssey speakers with the possible exception of the Lorelei.  When I bought my Lors I also picked up a Nemesis.  It's a great center, very articulate, clear, handsome and as I said, voiced exactly to the Nightingale, Circe and Epiphony.  For me, though, it didn't have enough to keep up with the Lors so I went another direction.
That said, it's going to depend on your other speakers and how they are voiced.  The ring radiator tweeter used in the LSiC has a very specific voice to it which is very different from the Nemesis.  I would also say the LSiC probably has a little more low end grunt.  However, if you're using this mostly for movies and not 5.1 audio then that may be less of an issue.  The nemeis was great at dialog.
BradSD
Nemesis
« Reply #2 on: 16 Nov 2005, 11:05 pm »
I have Polk all around, but funny you should mention the Lor's, those are the speakers on my short list right now...hence the Nemiesis question.
What rout did you end up taking to match the lorelei's?
