A/V HT review
0 Members and 1 Guest are viewing this topic. Read 2494 times.
samplesj
A/V HT review
« on: 16 Nov 2005, 02:07 am »
Ok, I've had this system built and running for a while so its probably time I get around to posting a brief set of comments (a very mini review if you want to call it that).
1 pair of A/V-3 mains
1 A/V-3s center
1 pair of A/V-1RS surrounds
I'll try to get a few pictures snapped in the next little bit, but just as a heads up, these are in a dedicated HT room so I wanted a non-reflective look.  The front three are plain MDF painted flat black.  The 1RS' are painted very dark ivy green just like the walls so they blend in very well too.  Both paints were left over from the walls and ceiling so it was low cost as an added bonus.  Seen in full lighting they are unimpressive compared to some of the very nice finishing jobs I've seen on here lately.  The finish does work very well for this room though.  I was in there the other night and actually noticed that I could only barely see the mains with the lights off and projector going.  The only thing that called out on all three in the front was a bit of glare on the center's glossy black woofers.  That amount of glare is only a minor nuisance compared to my last speakers where everything was clearly visible and I actually had to cover the top of the center with heavy black felt to keep from washing out the picture.
Soundstage
One of the biggest things that I've noticed about these speakers is their amazing ability to get spatial cues right.  Not just left/right imaging, but also the type of room for the original recording.  With recordings of "live" music you can hear all of the original room’s ambiance.  With movies this is obvious with dialog in larger rooms/halls.  The new Star Wars movies have several good examples of this.  Padme's bedroom is a cavernous room and I can hear the reverb/echo in voices.  None of the speakers I've had before had this ability so at first I thought it was something my room induced, but I only hear it when the speakers in the movie are in rooms where there should be echo when you think about it.  My wife's friend that comes over for movies often doesn't hear it at all, but I've taught my wife to listen for it too.  It is really cool and greatly adds to the feeling of being there. The soundstage is huge, with the lights off and their flat black cabinets they just disappear.  Nothing about the sound helps locate the speakers themselves.
Detail
So I really like the soundstage, but what about their detail?  I think Danny has gotten an excellent balance between detail and not causing listener fatigue.  These speakers are just nice and smooth, but without making you feel like something is missing.  I can listen to these for hours at a time without having to gradually reduce the volume.  Compared to the pair of Onix Ref1s we have in the house I don't feel like I'm losing any detail, but I can't listen to those on the HK at all.  Even on tubes I can only handle the Refs for a while.  When I first built the A/V 3s I wanted to try them out on the tubes in the den just for grins.  They had a wonderful richness/lushness that I just don't get out the Ref1s in there.  If I'd had other speakers suitable for HT mains they'd still be in that system.  They had good warmth before, but on this tube integrated it was amazing.  I'd been teasing my wife about upgrading her speakers in there for a while, but she always pushed back since she was happy with what she had (and didn't want to spend more money).   Well once she came in the room I was told point blank with no prompting to sell the refs and build her another pair of those (the 3s).
Bass reach
As far as bass depth I think they are just fine for music as is.  In the HT system they are crossed at 60Hz, but I also tested them with my DIY integrated running full range (testing it really ;)).  On the digital amp with TVC volume control they were squeaky clean but not at all sterile.  I still had a nice warmth and aliveness to the music.  Overall I thought they sounded better on this gear than the tubes.  It sounded so good I couldn't resist and cranked it pretty high.  I actually put on some organ music playing around and I couldn't believe how good the bass sounded.  Of course the woofers were pumping like crazy and when I held my hand up near the cone I couldn't believe how much air it was moving.  I could be very happy with these in my new listening room, but I'm holding out for a line array.
System as a whole
As a HT system everything blends together very well.  When I first installed the center I wasn't sure if maybe it was a little tonally different, but I don't notice it now.  I'd been running the 3s for a couple of weeks so it was possibly break-in related.  I also have my center channel on an adjustable angled stand and I've tweaked that angle quite a few times.  Right out of the gate the stand would have been shooting a little low because it had housed a much bigger center.  Speaker break-in, listener break-in, bad angle making it too off-axis, regardless it is all a good mesh now.  At first I was a little dubious about the new surround design, but we're really enjoying them.  I was going to give them a shot and if I didn't like it then I'd just turn them into normal A/V-1s, but they really do work well for the surround info.  I can't pinpoint them which is good, but even though they are pointed at the ceiling it doesn't seem to sound muffled.
Equipment Used
HT system: (used to have separates, but QC issues ended up sending them packing.  The HK is a stopgap, but its worked so well I may just leave it alone)
receiver: HK 635
sources: Denon 3910/Dish 811
power conditioning: BPT 3.5Sig
room: 15X20 with first reflection treatments and 6 bass traps
Den:
integrated: Onix SP3
source: Onix XCD88
power conditioning: none
room: open to kitchen and entry foyer so very irregular - no treatment because its a common area
Briefly used in HT system with DIY Hypex UCD400/S&B TX102 stereo integrated amp instead of HK [2 channel music testing only]
Value
I had the HT system crippled with just a pair of monitors in front for a month or so before these were built so it is not fair to reference too much to the earlier HT speakers I had in here, but I don't feel like I downgraded at all.  Between "I built it myself" pride and short auditory memory I can't be sure and it isn't a fair comparison, but I think that this HT system is better than anything I had before.  These aren't just cheap speakers made to sound good on cheap receivers, because each time I threw better amps at it, they just sounded better and better.  Based on that I'd have a hard time believing they were the weakest point in the system.  I think the A/V series is a crazy value.  "Retail" on the previous system was $3300 and they replaced a $5000 system.  Luckily I sold my last system before the bottom dropped out of that company's speaker resale value so I actually got more on the resale than the GR kits cost.  Even after I finally get around to adding the last pair of speakers it should be under 75% of what I got from selling the others.  Although I was frustrated at times building the cabinets overall it was fun and a good learning experience so I'm considering all of my time invested as free.  Its cool when the upgrade puts money BACK in your pocket.  When I sold my 2 10" subs and built a GR dual 12" sub I actually got a router and a little pocket change out of the deal so for me if I don't count my time DIY has been a great money saver for me.
Next steps
Unfortunately now I've got to decide what to do with the last two speakers.  I only bought five at the time because I hadn't sold all of my old speakers yet and it was also a good way to make sure there were going to be a good match.  I'd thought about getting two more A/V-1RS', but another pair of 3s isn't really that much more and that would be nice for DVD-A/SACD.  Plus with another pair of 3s I could use the cabinet building/painting tricks I learned to get a better finish and swap with my current fronts.  Any suggestions/recommendations from other A/V HT owners?
eros28
A/V HT review
« Reply #1 on: 17 Nov 2005, 05:30 pm »
Samplesj
Great review! I'm glad to hear that you are enjoying your new speakers!
I have a question; can you describe the performace of your DIY Hypex amp with the A/V 3's? The reason I ask is that I'm thinking of getting the Hypex kit to make a 5 channel amp for HT.
samplesj
a few pictures
« Reply #2 on: 18 Nov 2005, 02:17 pm »
I'm not a photographer so these are the only pictures that ended up worth anything.  A couple of the shots had bad shadows because I stood between the lights and the target.
http://www.phoenixlogic.com/images/AVEq/AVHT/DSC_0073.JPG'>Full Front
http://www.phoenixlogic.com/images/AVEq/AVHT/DSC_0070.JPG'>Left Main
http://www.phoenixlogic.com/images/AVEq/AVHT/DSC_0072.JPG'>Center
http://www.phoenixlogic.com/images/AVEq/AVHT/DSC_0068.JPG'>Surround from a distance
http://www.phoenixlogic.com/images/AVEq/AVHT/DSC_0069.JPG'>other Surround close up
I had the most trouble with the surrounds.  I had finally gotten a 3/4" roundover bit so I wanted to use it on them.  All of the other speakers are 3/8".  Unfortunately the bit was too big for the plastic glide pad on the bottom of the router.  I did the first one freehand with it just sticking out in the air, and I wasn't even close to level.  If you look closely at the close up you can see it kind of warbles.  I took the plastic off and just slide it along the metal base for the other and it turned out ok, but it was awkward to use without the plastic to glide on.
I first mounted the surrounds directly against the wall, but went back later and added rubber cushioning so they didn't rattle.  Unfortunately this cheap flat paint scuffs and marks easily so I'll have to touch up around them.
The notch on top of the 3s is a second roundover.  I hadn't figured out the flush cut bit trick when I built those so both of them came out a little tall.  As a fix I ran the router over both edges.  I'd have preferred a flush line, but several people have thought I did it on purpose for added decoration so evidently I've gotten away with it.
Sorry about the white dust everywhere.  It is hard to find that without the focused flash and even when you see it, it is incredible hard to clean.  That room used to have a popcorn ceiling texture.   If you are having a house built or refinished DO NOT let them popcorn the ceiling.  It is a nightmare to get off and it takes forever to get cleaned up.
The sub in the pictures is a thrown together box.  It was my first project and I was in a big hurry.  Its on my list to redo so it matches the other speakers, but once something is working its hard to come back to it and take it apart.
samplesj
A/V HT review
« Reply #3 on: 18 Nov 2005, 03:48 pm »
Quote from: eros28
Samplesj
Overall I think the UCD and 3s would be a great match.  I don't think its too dark for the less bright 3s.  I also don't think its too bright and makes the 3s lose their magic.  I've heard the 400s with a $5 pot, using the HK as a pre, and finally with the TX102s.  I've not been disappointed with it in any of those cases.  It has been dead quiet from the speakers even right up at the tweeter at full volume (after I fixed the molex kk connector with loose wires from hypex).
As good as I thought the 3s sounded on my wife's tubes, it was even better with the UCD/TX102s.  That combo had almost all of the midrange seductiveness, but clearly had much better bass.  It was also much cleaner (blacker, whatever you want to use).  The heat factor is just plus.
wshuff
A/V HT review
« Reply #4 on: 18 Nov 2005, 10:41 pm »
What kind of stand are you using for the center channel?
samplesj
A/V HT review
« Reply #5 on: 21 Nov 2005, 07:04 pm »
Quote from: wshuff
Lovan M2S-CTRD
The stand is really out of place with the current center.  I had used it eariler for a larger center that had sounded much better pointed more at the listener.  I used to use a quick and dirty DIY cedar bench style support, but it couldn't be cut down any lower and I was also worried about too much rake making the center just slide off.
Jeremy
