Bugle build question
0 Members and 1 Guest are viewing this topic. Read 1481 times.
analog97
« on: 15 Nov 2005, 06:03 pm »
I think I now have the skills (after building the Cornet2) to attempt to install a Bugle inside an existing old phono pre-amp case.  My main questions are : 1.  can I use Auricap scrap wire to run from the existing RCA's to the Bugle pcb?  2.  How to wire the existing power supply from the Parasound to the Bugle pcb ( I am guessing that the voltage is fine, but I can check with a DMM) and 3. does the engineer mind my putting a Bugle in a case with another name?  Thanks again (and no, I am NOT interested in replacing the Cornet2...just curious about that review which placed the Bugle above that DACT-100)
hagtech
« Reply #1 on: 16 Nov 2005, 01:31 am »
1)  Any wire ok.
2)  Find 3 terminals: Vcc, Gnd, Vee.
3)  No problem.  Done all the time.
jh :)
