How can I reset the SP1.7 back to factory default settings
0 Members and 1 Guest are viewing this topic. Read 3891 times.
georgev
Just wondering if anyone can tell me how to reset my SP1.7 back to the factory default settings.  I have had a few problems with my sub not getting any input in DTS 5.1 DVD's.  I'm hoping if I go back to the default settings this problem maybe corrected.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #1 on: 16 Nov 2005, 06:22 pm »
HI,
IR code '254' should reset almost everything to factory defaults, given a relatively recent software version.
james
georgev
« Reply #2 on: 17 Nov 2005, 12:57 am »
Thanks James.  I have software version 44F and that code worked great.  It reset all the settings.  I will now try again to configure my SP1.7.  But this time I'll keep it simple and test the sub output as I go.
James, I have tried to find the hidden codes on the bryston website.  But, I was unable to find them.  Can you send me a link to the codes.  Thanks.
« Reply #3 on: 17 Nov 2005, 06:16 pm »
Quote from: georgev
Your right - they are "really hidden".
I will find out where they are hidding.
james
« Reply #4 on: 18 Nov 2005, 04:15 pm »
OK after much searching and many hours of frustration I found the "missing link"
Go here - http://www.bryston.ca/BrystonSite05/BrystonDocs.html#preamp
Then click on the SP1.7 under Memos and Misc - then SP1.7 Hidden Codes.
james
georgev
« Reply #5 on: 18 Nov 2005, 06:31 pm »
Thanks.
flom
« Reply #6 on: 27 Apr 2006, 04:19 pm »
Hello, the "SP1.7 Hidden Codes. " is not available anymore?
Could you please give again the shortcut?
Cheers
Fabien
« Reply #7 on: 28 Apr 2006, 01:47 pm »
Quote from: flom
Cheers
Fabien
Code  - 2-5-4
DTS - Dig- Surr
james
flom
« Reply #8 on: 28 Apr 2006, 01:52 pm »
Quote from: James Tanner
Quote from: flom
Cheers
Fabien
Code  - 2-5-4
DTS - Dig- Surr
james
Hello James, in your previous post, you were just mentioning the "hidden codes" link in www.bryston.ca
My question was more about the list ...
Fabien
« Reply #9 on: 28 Apr 2006, 01:56 pm »
Yes  we are changing some of the codes.
james
flom
« Reply #10 on: 28 Apr 2006, 02:01 pm »
james
And therefore, you will put the internet link available again?
Thx
Fabien
« Reply #11 on: 28 Apr 2006, 03:34 pm »
yes
james
flom
« Reply #12 on: 28 Apr 2006, 05:49 pm »
Thx James. Do you have an approximative scheduled date?
Cheers
Fabien
