Dodd balanced power conditioners
0 Members and 1 Guest are viewing this topic. Read 1977 times.
brj
« on: 14 Nov 2005, 05:37 am »
Hi Danny.
I had a couple of questions for you based on your most recent comments in the NTAJ thread. This is one of two threads I started to avoid side-tracking the jam scheduling thread too much...
Regarding the new Dodd power conditioners, can you relay pricing and availability?  I didn't see anything on Gary's website...
Do they come with power cords?  (I didn't see any in your pictures.)
(I like the gauge on the front - a simple thing, but surprisingly useful, and oddly overlooked by many other manufacturers!)
RAW
« Reply #1 on: 14 Nov 2005, 04:14 pm »
Power supply info:
8 outlets all hospital grade cryo treated plugs
4 dedicated to frontend componets
4 dedicated to amplifiers. 2 for analog amps and 2 for digital amps.
Extensive filtering for emi/rfi/surge on the mains coming into the unit.
More filtering on the frontend plugs and even more filtering on the 2 plugs for digital amps.
Analog meter on front tells you at a glance how much of the available power is being used.
Uses hyd/mag breaker for protection and power switch.
IEC power connector so you can use any power cord you like with the units
Offered in an 800 watt unit and a 1500 watt unit.
Retail for the 800 is $1490.00
Retail for the 1500 is $1690.00
There are other finishes for additional cost.
Standard is brushed front and Oak sides
This is the info Gary sent me as we are going to be a dealer for him in Canada.
