0 Members and 1 Guest are viewing this topic. Read 3565 times.
Wow, something's not right then. A new cd, with no error detection really going on, should spin up and rip at 12x on average or so, meaning about 5 minutes. Did the report show any errors?
The ripping processing time is almost entirely dependent on two main issues:1) the error detection method/accuracy; should be "c" and "secure" for best rips, but will potentially take longer because you are asking it to reread and reread until the log fills, then go to the next bit)2) the physical shape of the cd. Cd's with many scratches can take a long time; brand new cd's can take 5 minutes. I use discdoctor on a cd if it looks like its hanging up on a certain area (you can see the error correction ...
You forgot cd burner properties and cpu.I know that with my odl PIII the fastest I can get is around 10x (it is usually around 6-7x). This same burner in another computer can go much faster.I have also seen times where I need to recycle EAC to get speeds above 1-2x.George
