Best performing DVI-D cable on the market???
0 Members and 1 Guest are viewing this topic. Read 1510 times.
Reference Audio Mods
    • http://www.referenceaudiomods.com
« on: 9 Nov 2005, 09:39 am »
Hi,
Looking for opinions or posted reviews of the best performing DVI-D cables on the market. I only need 1 meter cable..  and price isnt an issue but I do not want to overpay for something that necessary isnt the best..
I am looking at Wireworld starlight (1Meter), the monster M500 (dont know if its junk), and some others. Just want to upgrade the stock cable that came with the OPPO dvd player to the best there is.
Thanks in advance...
StevenACNJ
« Reply #1 on: 9 Nov 2005, 12:32 pm »
http://www.audioadvisor.com/store/productdetail.asp?sku=AQDVI31&product_name=DVI-3%20DVI-D%20Digital%20Video%20Cable
I conducted the same search several months ago and selected the above cable. The cable was very well constructed and I was pleased with my purchase.
Charles Calkins
« Reply #2 on: 9 Nov 2005, 12:42 pm »
Try one from bluejeanscable. Everythimg I bought from them has been very good.
                                     Cheers
                                       Charlie
mshan
« Reply #3 on: 9 Nov 2005, 03:18 pm »
These seem interesting and not too expensive:
http://outlawaudio.com/products/cab_dvi_about.html
(description of HDMI cable says they use OFC and oversize conductors)
« Reply #4 on: 9 Nov 2005, 03:45 pm »
Quote from: StevenACNJ
Hi Steve,
Did you ever compared a stock DVI cable in the setup and switch back and forth with the DVI-3 AQ cable and what the difference was?
I might take up the AA 30 day money back and test out the DVI-3 (even though I know I would be paying full price, but that is really not a issue).
I will be using whichever DVI cable with a heavily modified OPPO 971H DVD player (with latest firmware) feeding into a Winbook LC-32 LCD display (This display is absolutely awesome looking for the money!).
I appreciate the replys and welcome any others as well, I will look into each.
