0 Members and 1 Guest are viewing this topic. Read 5460 times.
Thanks.. certainly helps. Come to think of it, already having some bass problems when the double bass hits the real low notes... I don't think I want to hear those notes below 40...
In fact, my particular room's bass bumps are so big that inserting enough bass traps to cure the bumps sucked all the life out of the rest of the music (I tried two 4' tall x 4' diameter Tube Traps, their largest). Bass traps can kill a patient while curing his symptoms.
Can resonators correct narrow 12 dB bumps centered at 30 & 80 Hz? How much is the approximate cost & dimensions?
Very helpful, thanks.For rooms having only one or two bumps, it appears to by purely advantageous to use only a parametric eq & no mechanical solutions to eliminate the bump(s). The inverted EQ of the bumps decreases subwoofer distortion & increases output capability, sometimes very dramatically. A Helmholtz resonator will mechanically eliminate the bump, but offers no SPL/distortion advantage. Plus resonators take up more space & must be integrated with the decor. EQ is easier to hide.
