Too many HDMI sources and not enough inputs? Check this out!
0 Members and 1 Guest are viewing this topic. Read 958 times.
byteme
Key Digital has announced a new HDMI 4X1 switch to solve your problem.  Check out this feature list!
HDMI 4x1 is a timely 4x1 HDMI Switcher (with HDCP) that switches any of four (4) inputs of HDMI A/V to one (1) output, also conveniently switching multiple audio formats. HDMI 4x1 is much more than a switcher, as Key Digital's® renowned Clear Matrix Pro technology can scale the selected video input to match the native resolution of your display. All the video processing features you'd expect from Key Digital® are also provided. Use the convenient front-panel display and pushbuttons, the IR Remote Control, or RS-232 to easily control all features of the switcher. The HDMI 4x1 processing is all-digital, providing the absolute best, crystal-clear, and pristine switching and picture quality you can attain.
General
• Crystal-clear switching and HDMI repeater functionality of four (4) HDMI Inputs to one (1) HDMI Output, with HDCP
• Switches Video and Audio with individual connectors for HDMI Video and Audio, Toslink Optical Audio, Digital PCM Audio, and Analog stereo Left & Right Audio
• Can also scale and process any HDMI video input to match the native resolution of your display, storing your custom settings for each input
• Supports all popular high definition and standard definition source and display formats and resolutions, at 60 Hz and 50 Hz
• Easy to control and operate, with convenient front-panel display and pushbuttons, IR Remote Control, rear-panel remote input, and RS-232 (compatible with Crestron and all control systems, and is Firmware upgradeable)
I'm an authorized Key Digital distributor - you'll find this elsewhere for the retail of $1800, I can get it to you for $1175 shipped in the 48!
