Does anyone want to comment on the HTC?
0 Members and 1 Guest are viewing this topic. Read 1730 times.
pugs
« on: 28 Oct 2005, 03:43 am »
I have a pair of HT3's and an HTC on order.  There has been a lot of feedback for the HT3, but pretty much none for the HTC.  Is there anybody out there that can provide some feedback/impressions of the HTC?
Marbles
« Reply #1 on: 28 Oct 2005, 12:41 pm »
Mine matches the HT3's VERY well.  You should like the combo.
I have found nothing to pick nits about with the HTC or the timbre matching to the HT3's.  Mine is XO'd at about 70 HZ to my subs.  HT3's are run full range.
jermmd
« Reply #2 on: 28 Oct 2005, 01:29 pm »
I ordered an HTC to use with my HT3's but it hasn't been built yet. I would have preferred the HT1 for a center channel but it was too tall to fit under my screen. I'm glad the HTC matches up well with the HT3 as this is my primary concern. For music, I will run my HT3's large but for movies I will probably cross them over with the HTC (possibly as high as 80hz). I'll post after everything arrives and is set up. It shouldn't be too long now for the HT3's.
