Crossover components
0 Members and 1 Guest are viewing this topic. Read 2463 times.
Christophe35
« on: 23 Apr 2003, 02:13 pm »
Hi  everyone,
As this is my first post here, here is a short presentation. I'm a french audiophile, my system is composed as folow:
AH njoe tjoeb 4000 cdp
Odyssey tempest
Odyssey mono blocks
Dynaudio DIY gemini with crossovers in separate boxes, close to the amplifiers
Groneberg interconnect
Jamo speaker cable (yes:-) the weakest link of my system, to be upgraded, maybe to groneberg).
Now, the topic of this post: Klaus, what components do you use in the crossover of your speakers ? I'm using actually tritec self and audyn cap plus, both from intertechnik, and plan to use MOX resistors. Do you think copper foil inductors can be better than tritec ? what about intertechnik copper foil inductors ?
Any information and advise about crossover components is welcom.
Christophe
scottpretti
Gemini done right
« Reply #1 on: 23 Apr 2003, 07:30 pm »
Check out this BESL page and check out what Phil has done with the Gemini xover.
http://www.bamberglab.com/gdr.htm
Christophe35
Re: Gemini done right
« Reply #2 on: 23 Apr 2003, 09:18 pm »
Quote from: scottpretti
Thanks for the link. I already know the "gemini done right" crossover, even if I didn't listen it. I forgot to mention that I don't use the stock crossover but the one developped by Dennis Murphy with some modifications.
Christophe
