Clari-T with High Impedence Loads
0 Members and 1 Guest are viewing this topic. Read 1993 times.
JDUBS
« on: 26 Oct 2005, 03:59 am »
Vinnie
How well does the Clari-T handle higher impedence loads?
I'm picking up a pair of Oris 150 horns this weekend and they have the AER MD-3 drivers....which I believe represent a 12-ohm load (and 109 db / 1 watt efficiency!).
Would love to buy one of your amps to accompany these guys!  :mrgreen:
-Jim
Vinnie R.
    • http://www.vinnierossi.com
Re: Clari-T with High Impedence Loads
« Reply #1 on: 26 Oct 2005, 11:25 am »
Quote from: JDUBS
Vinnie
-Jim
Hi JDUBS,
From the feedback I have received from customers with higher impedance speakers (Zu speakers, Lowthers, etc), the Clari-T works very well with them.  You can also experiment with installing a resistor across the + and - terminals of each speaker to present the Clari-T with a lower impedance load.  For example, a 15-ohm resistor in parallel with your 12-ohm (nominal) speaker will make the amp see a load approx 6-ohm.  Yes, some power is wasted in the resistor, but wow...109dB speakers!  The Clari-T will be a total muscle amp for them!  :mrgreen:
You'll never know until you give it a try.  Feel free to contact me if I can provide additional information.
miklorsmith
« Reply #2 on: 26 Oct 2005, 02:33 pm »
The Zu Druids are a 101 db speaker at 12 ohms and they did fantastic with the Clari-T.
109?!  Good luck with the volume control!
JDUBS
« Reply #3 on: 27 Oct 2005, 04:12 am »
Excellent!  Just what I suspected (and quite frankly, wanted to hear  :D )
Yes, volume control will be an issue....don't quite have that worked out yet.
Another thing...the Oris's cover from ~150hz on up.  I have some bass cabinets (Oris Reference Bass Cabinets) which handle the lower octaves.  The bass cabinets are ~100 db / 1 watt efficient and represent an 8 ohm load.  Would be awesome if I could run these both off the same Clari-T (somewhere >100 db efficient on a combined basis with impedence <12 ohms).
Thanks again, guys!
-Jim
Paul_Bui
  • Rode NTK and S-1 microphones
« Reply #4 on: 27 Oct 2005, 08:57 am »
Or, you can use two Clari-Ts to vertical bi-amp the speakers.  Ask Vinnie to adjust the gain so that you don't have to watch the volume control too closely.
