0 Members and 1 Guest are viewing this topic. Read 3209 times.
I'm trying to use SB2 with a downstairs computer while my music is on the upstairs computer (in folder "music" of drive C). What address do I put into "music folder" on the downstairs computer? I wish they had a browse button next to the address space.Joe
So you can control it from a computer that doesn't have the songs? That's cool. When can I come over and check it out?
Here's another possibility: Create a music folder on the downstairs computer. In the folder, put a single file: a shortcut to the upstairs computer's music folder. Just right-click from Windows Explorer or My Computer in the downstairs computer's music folder, and select New | Shortcut. Then follow the instructions for completing the shortcut. There's a browse button where you can browse to the upstairs computer. Then point your SB to the downstairs computer's music folder with this shortcut in it, ...
(if you can't find this local web address, I can help you find it).
A off the beaten path question, but I got a Squeezebox 2 today and I noticed that the acrylic window that is in front of the display is a tad shot in one side, thus exposing the inside part of the case....the side next to the IR receiver. Is this common or do I have a defective unit?
