Magnepan/custom speaker stands, custom audio racks.
0 Members and 1 Guest are viewing this topic. Read 6083 times.
grantv
    • http://www.myesound.com
« on: 18 Oct 2005, 07:21 pm »
Mye Sound have manufactured over 200 pairs of Magnepan speaker stands to date. All stands offer improved stability, better focus/clarity.... Please see website and testimonials for more information. Custom racks, amp stands, speaker stands, etc available on request. Reasonable prices.
All stands are manufactured with heavy wall tubing, are sandblasted for better finish adhesion, powdercoated for a rock hard finish and have welded end caps for a very solid feel (no plastic furniture caps here!).
Brass points and all required fasteners are included.
TheChairGuy
« Reply #1 on: 18 Oct 2005, 08:03 pm »
Dang, you know Grant, I still owe you a good pic of my MMG's mounted on your fabulous stands.
Folks, if you have Maggies of any size and plan to keep them and make more music from them, Grant's stands are the first and most important upgrade you can make with them.
Best of all, they save you burial costs when you expire....the stands come in a 'built-for-the-ages' coffin that can be used as a handy casket (if you're short). They will withstand the rigors of UPS wherever you are- most assuredly  :)
Regards, John
grantv
Thanks John!
« Reply #2 on: 20 Oct 2005, 02:22 pm »
The caskets, I mean crates, do stand up to pretty much anything, anywhere. You'd be surprised what shipping companies try and do. :) Pictures would be great, I have a couple to hold me over for now. Thanks again for the compliment.
TheChairGuy
« Reply #3 on: 25 Oct 2005, 07:37 pm »
I didn't take pics of the caskets (a bit morbid, eh?), but here are some shots of Grant's OCD-inspired work  :wink:
They are the first MMG full stands with base and stanchions he made - and they are perfectly finished.  No prototype mistakes or teeting and with these guys.
The MMG's are $550 and the stands cost $383.00 landed here (may be a bit more with higher UPS rates in effect now)....without stands I was a mite disapointed with the MMG's - even for $550.  With the stands, they rival any sub-$1000.00 speaker I have ever heard. Of course, that's a purely subjective opinion  :)
Tho you can't see it - they are sand filled and weighty.  Major kudo's on cosmetics too...right down to the classy and heavy brass points that they come packaged with.
