Power conditioner
0 Members and 1 Guest are viewing this topic. Read 6025 times.
  • The Demo is Everything!
    • http://www.bryston.com
Power conditioner
« Reply #20 on: 4 Dec 2005, 11:54 pm »
HI Jason,
We are introducing them at the CES show in January in Vegas.
There will be 6 models from $2300 to $8000.
We will only be releasing the 120 volt units to start with.
We  have quite a few pre-release orders from some dealers which they will receive in late January.
james
Jason Nugent
Power conditioner
« Reply #21 on: 5 Dec 2005, 12:57 pm »
So, that means that the 240V unit will be available for a while, correct?  hmmm.  That's a bummer.  not being able to run power into my room is seriously cramping my time table :)
Power conditioner
« Reply #22 on: 5 Dec 2005, 01:29 pm »
Hi Jason,
You will be able to run 'split phase' 120 (120x2=240) for balanced power line.
Given your in Canada are you running 240 volt to your audio system?
james
Jason Nugent
Power conditioner
« Reply #23 on: 5 Dec 2005, 02:18 pm »
Oh, I thought you meant that the split phase 240V units wouldn't be available.  Yes, that will work nicely.  Thanks!
Occam
Power conditioner
« Reply #24 on: 22 Dec 2005, 11:02 pm »
Mr. Tanner-
From your marketing literature-
http://toruspower.com/Documents/Torus%20AV%20Rack%20Spec.pdf
bolding added by me
Torus PIUs use two phases of 120VAC for
a 240VAC input to a center-tapped
transformer (120V-0-120V). The centertap
is grounded. This technique is similar
to Balanced-Power output systems (60V-
0-60V) which are proven to reduce noise.
Balanced output systems, however, are
restricted in their use by Electrical Codes
to “Technical Power” applications. They
must also include GFCI (ground-fault
circuit interruption) outlets, which are
prone to nuisance trips.
Specifically how are these techniques similar other that the use of the words 'split-phase' in their descriptions? Split phase input cannot provide the specific benefit of cancelling reactive leakage currents in the grounded components it feeds, as does real technical power. (Well... actually it will cancel the reactive currents from the primary of the Torus transformer itself.) While balanced output (technical) power can be demonstably proven to substantially reduce noice, what exactly does split phase input do? Simulations, equations, or actual measurements would be most appreciated.
'Prone to nuisance trips'????? I wouldn't think the very finely engineered products from Bryston would cause such. Nor have I ever experienced such on any competently engineered product. 5ma of leakage (the typical trip setting of a GFCI) indicates a serious problem. These 'nuisance trips' will be a real surprise to the owners of Equitech, BPT, Furman, etc... balancing conditioners.
[EDIT - Rereading my last paragraph, I realize the mention of nusiance trips is quite germane. Give the power ratings of these Torus offerings, I realize that the target market isn't specifically home audio/theater, but rather small and large venue environments, small clubs, on stage performance ..... Its highly likely that an artist might well show up with their beloved 40+ year old guitar or bass amp. The often have the neutral tied to chassis (that been a no-no per UL for over 30 years) and would inevitably cause a nusiance trip. Such a trip the GFI in balaced conditioners is far prefferable to the other potential of electrocution. Given the vaugaries of what specific equipment a performing artist might show up with, that avoiding nusiance trips is very  important.
Power conditioner
« Reply #25 on: 23 Dec 2005, 01:06 pm »
Hi Occam,
I am checking with the designer of the power conditioners on your question.
james
