voltage trouble
0 Members and 1 Guest are viewing this topic. Read 1412 times.
pixies
voltage trouble
« on: 14 Oct 2005, 06:52 am »
I have a stratos mono / tempest + lorelei system and I was wondering if anyone of you was using a power regulator or ups source or something else with the same functions. I need something like this because the voltage (220-240 here) varies a lot. I left all my equipment turned on and nothing appeared to be wrong but I am not sure anymore. The power supplied to my house falls once / twice a week. So I searched some products but I do not know how to choose. Need help. Thanks.
Brian
voltage trouble
« Reply #1 on: 14 Oct 2005, 07:04 am »
Hello Pixies
First of all, welcome to Audiocircle.
I have no experience with such equipment, so I can not help you.
Brian
Off Topic: Where do you live? Looking at the voltage (240) I assume that you do not live in the US. Are you from Europe?
Sonny
Re: voltage trouble
« Reply #2 on: 14 Oct 2005, 04:00 pm »
Quote from: pixies
Hi there Pixies...
I would recommend a Monster AVS 2000, its a Voltage Regulator, exactly what you need, and there is one on sale on audiogon for less than $700 which is darn cheap!
Pick it up!
Sonny
Randy
voltage trouble
« Reply #3 on: 14 Oct 2005, 04:14 pm »
Check out Audiophile aps.
http://www.Audiophileaps.com
pixies
voltage trouble
« Reply #4 on: 14 Oct 2005, 05:41 pm »
Brian is right: I am from Europe. This clears the monster avs as it ships only in the US. I am still searching. Until then I am shutting down the system when not listening for more than one day.
