Building Speaker Stands
0 Members and 1 Guest are viewing this topic. Read 1249 times.
drcruz
« on: 7 Oct 2005, 02:32 pm »
I'm thinking about building speaker stands.
- I'm going to construct an open top wooden box, then give it a nice finish.
- Then I'm going to fill it w/ some of those grey bricks. (roughly 1.5" x 6" x 12" - or a close equivelant)
- The bricks will be glued together. Then I will glue a felt cover over the opening.
- The box of bricks will stand about 10" tall. Height of the box sides and bricks will be even.
- Finally a 31"h x 14"w x 11"d speaker w/ speaker spikes will sit on top of this box - spikes will anchor to the bricks.
My question, is this a bad idea, good idea, or doesn't matter???
Should I use the coasters or not???
Thanks in advance :-)
drcruz
« Reply #1 on: 8 Oct 2005, 01:55 am »
One thing I forgot to mention was...
The goal was not to put speaker spike holes in the carpet.  I'm new to this  Mid-Fi Audio stuff, so I'm not even sure if spike holes in the carpet is anything to worry about.
Thanks again  :)
andyr
« Reply #2 on: 8 Oct 2005, 10:42 pm »
Quote from: drcruz
Thanks again  :)
Hi dcruz,
I suggest spike holes in the carpet are nothing to worry about ... unless it's an antique Persian!  :D
The "spikes" under my speakers are 1/4" bolts, filed to a point; they do leave a small hole in the plush but after a bit of walking on this (when I've moved the speakers), you can't see the hole any more.
However, your idea of a box (more usually filled with sand than blocks) might have some merit. Spikes hold the speaker steady but they do couple it to the floor and if this is a suspended wooden floor, you might have some problems.  People espouse the "sand box" idea to decouple the speakers from the floor - go look at Audio Asylum.
Andy
drcruz
« Reply #3 on: 10 Oct 2005, 06:32 am »
COOL, Thanks for the input...  :)
