Anyone where I can get a Leak stereo 20 serviced ?
0 Members and 1 Guest are viewing this topic. Read 3228 times.
Don Maico
One of the input valves seems unsteady that is one channel does not work too well without twiddling the relevant valve around. It either hums, makes a scratchy noise or nothing. My guess is that the valve seat needs replacing
roymail
  • Roy in TX
Leak repair needed
« Reply #1 on: 20 Jan 2006, 05:44 pm »
bulgin
    • http://blueangelaudio.com
Anywhere I can get a Leak Stereo 20 Serviced?
« Reply #2 on: 13 Mar 2006, 08:09 pm »
Hi Don
I'm a longtime Leak Stereo 20 user. My guess is that it could be a "Leak"ing cap problem. Here in South Africa, we have a marvellous guy Wim Bouwman (aka Mr Valve), resident in Johannesburg. Wim is also a Stereo 20 fan and has a cap replacement kit on 2 pc boards, supplied complete with d/sided tape backing, which fits underneath out of sight. The idea is to leave the old caps and their cans in place but disconnected and replace these with Mr Valve's cap sets. Mine has been tweaked this way some years back and it was the best change I ever made.
I'm sure if you google either Wim Bouwman or Mr Valve, you'll find his email address.
Cheers
bulgin
timothyharnett
Re: Anyone where I can get a Leak stereo 20 serviced ?
« Reply #3 on: 9 Oct 2006, 11:14 pm »
Are you in North America or elsewhere?  In the UK you'd use either Classique Sounds, London Sound or GT Audio.  I use Classique for my St 20 - Paul is a Leak specialist.
The good thing is that ST20s are cheap to repair.
Don Maico
« Reply #4 on: 11 Oct 2006, 11:17 am »
Thank you for your reply :thumb:
