Help! Optoma H31 or Infocus 4805??????
0 Members and 1 Guest are viewing this topic. Read 1151 times.
gorgeousgeorge
« on: 3 Oct 2005, 07:13 am »
Hello,
helping a friend buy a projector, has anyone seen both these in action,
what would you recommend?
any help would be greatly appreciated.
Cheers, George
LadyDog
« Reply #1 on: 3 Oct 2005, 01:56 pm »
George,
Both are excellent projectors, especially for the money.  This is really a no lose situation as your friend would/will enjoy either one.
The 4805 is more of a plug and play projector as it will come out of the box pretty much set.  The H31 needs a bit of tweaking to get its picture to look best.
Imo, the H31 has a bit more pop to its picture.  The colors stand out more.  Depending on your view, this may be a positive or negative?
Lastly, while the blacks on the 4805 are very good, I thought there were better on the H31.
A positive for the 4805, it has better bulb life.
As previously stated, both are great so maybe costs will be the deciding factor?
Jeff
werner52
« Reply #2 on: 5 Oct 2005, 03:09 am »
I own a H31, so I can only comment on that model.  Got it at a great price and used video essential for fine tuning the picture.  I previously owned a Sharp DT200 and the H31 is quite a step up from that projector, albeit at even a lower price.  I haven't researched any current models, but at the time Optoma won out for me.  At the prices for these models I plan on using it for 3-4 years figuring then XGA's may be the entry level price point as SVGA's are now.
Positives:  Excellent black detail, bright vivid picture, quiet operation (The H30 had a weird pitch to the fan IMO).
Negatives:  Can't quite get reds to look really blood red, has a lean towards red/orange, have heard about some issues when using HTPC, however I use a standalone player and it performs flawless.
