Does anyone know how much a dual clari-t costs with the upgrades. My speakers are only 89db so not the most effecient. Stupid quesiton, but does 2 clari-t's give me more volume?
also how would you go hooking up a powered sub to one of these?
My plans are to use a squeezebox2, plugged directly into my ART di/0 modded DAC. then directly into the clari-t's
Dan
Hi Dan,
Welcome to the Red Wine Circle!
Regarding pricing info on a dual-mono, it depends on the upgrades, features, etc. A ballpark figure of a dual-mono amp with all the major upgrades (no volume control, input select switch, etc) is around $999.00.
I am in the process of updating the Red Wine Audio website, and plan to better organize the Clari-T-Amp customization options and pricing info. I'm been meaning to do this for a while now, but have been too busy keeping up with so many other things...
This will be finished after RMAF.
You can't connect a dac with a constant volume control directly to a power amp. You'll need a premap (passive or active), which can be as simple as a passive volume control. Or, you might be able to use the SB2's volume control for the digital output to your dac. Another option is to have your SB2 modded with battery power and plenty of tweaks that will make its volume controlled output stage sing with the Clari-T:
http://www.redwineaudio.com/SB2_Mods.htmlAs for a subwoofer, you cannot use the speaker outputs of a Tripath amp if the subwoofer ties its L- and R- terminals together. See:
http://www.redwineaudio.com/SB2_Mods.htmlIf your sub has line-level (RCA) inputs, you can try using a splitter to split the signal coming out of your preamp (or volume controlled dac) between the Clari-T and the subwoofer. Most powered subs have high input impendace, so you should be fine...
Hope this helps,
