Nirvana ease of retrofit
0 Members and 1 Guest are viewing this topic. Read 1652 times.
rick57
« on: 26 Sep 2005, 12:42 pm »
Hi
How easy (eg number of parts, approx time) is the Nirvana as a retrofit to the AKSA 100?
Richard
wmeckle
« Reply #1 on: 26 Sep 2005, 10:35 pm »
To upgrade from standard AKSA 100 to the Nirvana version.
Replace 4 Capacitors, and 2 resistors (on one board).
DSK
Re: Nirvana ease of retrofit
« Reply #2 on: 27 Sep 2005, 01:00 am »
Quote from: rick57
Hi
Richard
Richard, if you can swing the extra $, go straight for the Nirvana Plus ...much better performance.
EchiDna
« Reply #3 on: 28 Sep 2005, 01:51 am »
from memory when I went to the nirvana upgrade on my AKSA 100 it only took a few hours including dismantling and reassembly time.
Re-biasing etc adds a bit of time, but if you already have the 100 in stock form, then you know about this.
I did it over an evening and was listening again that night...
You will notice an improvement pretty much straight away and after letting it all burn in a bit the improvements keep coming.
