VPC-2 Now Shipping!
0 Members and 1 Guest are viewing this topic. Read 4548 times.
CIAudio
VPC-2 Now Shipping!
« on: 23 Sep 2005, 02:51 pm »
Our New VPC•2 Passive Controller is now shipping!
More info can be found on our website http://www.ciaudio.com
Tim S
VPC-2 Now Shipping!
« Reply #1 on: 23 Sep 2005, 05:12 pm »
That isn't the new remote controlled preamp you have mentioned before is it? The second set of outputs looks like a useful addition though.
Tim
BradJudy
VPC-2 Now Shipping!
« Reply #2 on: 23 Sep 2005, 07:17 pm »
Good to see.  I'm guessing you might have one with you at RMAF next week?
BTW: A suggestion for the website - can you place the product prices on that product's individual page in addition to the main page?  It seems a bit odd to flip back to the main page to see the price.
CIAudio
VPC-2 Now Shipping!
« Reply #3 on: 23 Sep 2005, 09:50 pm »
We're not displaying at RMAF, but AV123 will be using a VPC•2 in their demo system.
We put all prices on the main page so they're all in one place (like a price list). I can edit each page when I have time, but right now I have more important things to do  :)
CIAudio
VPC-2 Now Shipping!
« Reply #4 on: 24 Sep 2005, 12:31 am »
Quote from: Tim S
VPC•2 is an updated version of the original VPC•1.
The full function remote controlled preamp won't be out until early 2006.
-Dusty-
sas
VPC-2 Now Shipping!
« Reply #5 on: 25 Sep 2005, 10:54 am »
Dusty, sorry for bothering you with questions!
I need a DAC and preamp, and like the idea of your passive module. I've also been thinking of the benchmark DAC1 as a kind of all-in-one.
I would like to place monoblocks close to the speakers, and run long (around 30ft) shielded interconnects, low capacitance so I can keep the DAC/pre close to the listening position.
My monoblocks (norh 180wpc) have an input sensitivity of 1.8v and plenty of gain (i think).
Would a VDA/VPC combination be able to handle such long interconnects? I realise there would be compromises, but just wondering if this would be a really bad idea?
thanks for the help.
CIAudio
VPC-2 Now Shipping!
« Reply #6 on: 25 Sep 2005, 01:29 pm »
It would depend on the amplifiers input impedance and capacitance of the cables, but not ideal regardless. A better solution would be to place the amplifiers near the passive (with short interconnects), and use longer speaker cables.
sas
VPC-2 Now Shipping!
« Reply #7 on: 26 Sep 2005, 06:00 am »
thanks for the reply -- I thought as much.
When you say short interconnects, are we talking really short (like 50cm) or would something up to 2 metres be OK?
Next I'll ask you "how long is a piece of string?"  :oops:
CIAudio
VPC-2 Now Shipping!
« Reply #8 on: 26 Sep 2005, 12:36 pm »
Quote from: sas
2m is probably fine, what is the input impedance of your amplifier?
sas
VPC-2 Now Shipping!
« Reply #9 on: 26 Sep 2005, 02:19 pm »
Quote from: CIAudio
Quote from: sas
Thanks for the help.
The input impedence of my power amps are 44k ohms, and input sensitivity is 1.8v.
If I went the VPC/VDA route I would probably use DIY IC's using Belden 89259/Eichmann bullet plugs. Capacitance of the 89259 is rated at 17.3 pF per foot.
Hope that makes sense -- because to me they're just numbers...
CIAudio
VPC-2 Now Shipping!
« Reply #10 on: 26 Sep 2005, 04:58 pm »
If I went the VPC/VDA route I would probably use DIY IC's using Belden 89259/Eichmann bullet plugs. Capacitance of the 89259 i ...
Should be fine, the Eichmann's are also very low capacitance
